4507R-E 10G uplink connectivity & Documentation ?
patelvc7601
We have 4507R-E with 6L-E sup . I have twingig converter & X2 on following ports. We have dual sup & running sso. My question is how it determine which port is active ? Looking at the output te3/1 & te4/1 port is active .
I read the following high redundancy uplink guide :
http://cisco.biz/en/US/prod/collateral/switches/ps5718/ps4324/prod_white_paper0900aecd806ed38a.pdf
which talks about 2+2 redundancy but does not talk anything about how to configure the switch ?
I also look at following  configuration guide for 12.2(54)SG
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/54sg/configuration/guide/sw_int.html#wp1128472
which talks about shared backplane uplink mode on SUP 6-E & I do not see following command working for my SUP 6L-E
Switch(config)# hw-mod uplink mode
shared-backplane
Te3/1             notconnect   trunk        full    10G No X2
Te3/2             inactive        trunk        full    10G 10GBase-LR
Te4/1             notconnect    1            full    10G 10GBase-LR
Te4/2             inactive         1            full    10G No X2
I am big fan of the cisco documentation but as far as 4507 concern, this is disappointing ?
Sincerely,
Viral
Rahul Kachalia
Hello Viral,
In non-redundant mode (Single-Sup) by default both uplink ports can be used as 10G uplink or can changed to 1G as needed.
And in redundant mode  (Dual-Sup) by default second port is internally disabled to provide 1:1 non-blocking switching performance. If you need to use inactive port, then you can change the default backplane mode to shared-backplane and increase port-density, keep in mind now your switching performance will be 2:1 oversubscription. You can find additional detail of uplink configuraiton in Chapter 2 of following guide:
Borderless Campus 1.0 Design Guide
Shared-Backplane is only supported on Sup6-E hardware, the Sup6L-E is the lighter version of Sup6E supervisor and it does not support such capability...
thanks,
rahul.
6 Replies 6
Jonathancert_2
I want to make sure i understand your intent.   You want the ability to use the twingig interfaces on your 4507?
Jonathan,
I recently set up my 4507R-E for gig uplinks with relatively no problems.  If you are only using one uplink per SUP-6 you don't have to oversubscribe the hw-module (ie. hw-module uplink mode shared-backplane). I'm running IOS 12.2(53)SG, so your IOS should take the hw-module command if necessary.  Use the command:
"(config)#hw-module module ? port-group ? select gigabitethernet" to change the uplink speed.
Jonathan,
Rahul Kachalia
Hello Viral,
thanks,
rahul.
Rahul,
Thank you for the link & hope others will help by this Design guide.
Sincerely,
Viral Patel
johngebert
I am saving same problem. redundant 6-e supervisors. ver 12.2(40). hw-mod;  uplink word not allowed.
egarcial
It is still the same, Sup6L-E does not support the Shared-Backplane feature.
Sup6L-E Uplink Port Design
The Sup6L-E uplink port functions the same as the Sup6-E in non-redundant mode. However, in redundant mode the hardware design of the Sup6L-E differs from the Sup7-E, as the Sup6-E currently does not support a shared backplane mode that allows the active use of all uplink ports.
