4948 --- Qos for RDP
healthprime
hi all,
I want to configure Qos for RDP on 4948 Switch.As i have my client on other end .Users take RDP session and work on Server as basically users are taking Terminal Server access.I have 1800 users and simultaneoulsy 900 users connect to that server in one shift nd 900 in second shift due to which my links get highly utilized .So for this i need to configure Qos so is this possible to do .
vvasisth
In regards to your query, a great document to refer to is "Reference Guide to Implementing
Crypto and QoS" which is located at this URL -
http://www.cisco.com/en/US/customer/tech/tk543/tk757/technologies_tech_note09186a00800b3d15.shtml#sub5
Hope this helps
regards,
Varun
I have 4948 Switch 48 Port i need Qos setting for RDP can i do it in 4948 Switch if yes then please send me the docs for the same.
You can get all QoS Design and configuration models for 4500/4900 in the QoS SRND ver 4.:
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND_40/QoSCampus_40.html#wp1099634
Hatim Badr
