4948e vlan counters
martos1981
Hi all!
I have 4948e and as I googled - this device does not have vlan counters. When I execute:
show interfaces vlan 100 counters
The result:
Counters information is not available for Vlan100
Is there a way to use vlan counters or not?
5 Replies 5
rahurao
Hi Martos,
show vlan counters
To display software-cached counter values, use the show vlan counters command.
show vlan [id vlanid] counters
Syntax Description
id vlanid
(Optional) VLAN ID; valid values are from 1 to 4094.
Defaults
This command has no default settings.
Command Modes
Privileged EXEC
So i can we use the show vlan 100 counters and check the same?
Rahul
show vlan id 100 ?
  ifindex       SNMP ifIndex
  internal      Internal VLAN usage
  private-vlan  Private VLAN information
  uni-vlan      UNI VLAN information
  |             Output modifiers
These ara my options
I found the command "counter" in interface config but I am not sure why it exists.
show running-config interface vlan 3501
Building configuration...
Current configuration : 105 bytes
interface Vlan3501
ip address 192.168.1.1 255.255.255.252
counter ipv4
end
And again:
show interfaces vlan 3501 counters
Counters information is not available for Vlan3501
  "show int vlan X stats"   will give you counts.
Vlan80
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
               Processor          0          0          0          0
             Route cache          0          0          0          0
                Hardware   14690607 2222090681    8382032 1726621599
                   Total   14690607 2222090681    8382032 1726621599
Actually, after adding counter in the interface configuration the counters become working through SNMP
