5-4-3 rule of ethernet
unitech
Is this rule still valid in 100-TX (802.3u)
Can I extend the 100M limited distance of FE through using switch?
e.g ----cable(100M)----Switch----100M----Switch.....
lgijssel
Level 9
Level 9
The rule still stands...
You can extend the network in this way as while the collision domains are limited; however you will soon run into the next limit: seven spanning-tree hops per network.
The only viable solution for large distances is to use a Layer3 based solution, using routing instead of switching.
Leo
