connecting multiple 2950
daylight28
how do i connect 3-4 2950 so that i can use them as a single switch ?
what are the commands to make it work ?
you can use the CMS (Cluster Management Suite) software, or you can use the Command Line. Check the links below for both configuration options:
Configuring and Analyzing Clustering on Catalyst Fixed Configuration Switches
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00801347f8.shtml
Creating and Managing Clusters
http://www.cisco.com/en/US/products/hw/switches/ps637/products_configuration_guide_chapter09186a008007f23e.html
HTH,
GP
