Hi all,
While browsing around my 6500's, i discovered some error/fail counters incrementing (below in red). I'm been unable to find any info on what these are, or if they indicate any sort of problem. Any ideas?
Stuart
VSS012-c6513#sh ibc interface 1
Inband counters and statistics
Interface information:
Interface IBC0/0/0(idb 0xF5871D64)
5 minute rx rate 72000 bits/sec 62 packets/sec
5 minute tx rate 1565000 bits/sec 1719 packets/sec
202460173 Packets input, 31173658517 bytes
146605488 broadcasts received
8433992243 Packets outputs, 956373695324 bytes
200 broadcasts sent
411 Inband input packet drops
0 Inband output packet drops
1 IBC resets
*** Inband Generic Counters***
202460245 Packets Input, 1108887445 Bytes
146605528 Broadcasts Input
4139024820 Packets Output
634 Total Drops
0 software bridged paks
581218 Packets Fast switching paks
Potential/Actual paks CEF switched 31265514/270325
Potential/Actual paks tag CEF switched 28293243/581208
0 packets xconnect CEF switched
0 Packets xconnect L2 switched
0 packets xconnect dropped
0 Packets immediately punted
Potential/Actual paks copied to process level 85951954/85951731
Potential/Actual paks copied to L2 process level 79890051/79890051
80791625 Packets L2 processed
0 packets L2 switched
6 Encapsulation corrections
Internally intercepted packets:
7183833 exc, 84608754 dindex (80791625 sp, 0 old index), 50618350 cap1, 0 cap2
Earl8 shimmed paks rcvd:
0 pseudoipv6 0 svchdr 53147214 shim
*** INBAND PACKET DROPS & FAILURES ***:
0 shim_processing 0 shim_error
401 no idb 901574 get_l2_idb failures 72095381 if_input changes
8097301 intercept 0 spd
0 Number of times intercept function(s) returning incorrect values
0 bridge loopback 10 diag
0 Rx packets with unicast IP and multicast MAC
0 fastsend 0 soutput 0 no mac descriptors 0 NULL if_outputs
223 throttle 0 throttle sneaks
0 encapsulation 49950100 get_lif
0 if_input corrections 0 uncorrectable if_inputs
0 corr ecc errors
0 null parse packet
243128496 shim insertions attempted at tx, 49950098 failed
0 times les cef vector not set
