6500 VSS and Nexus 7000 routing??
alex.fritzsche
Level 4
Level 4
first of all - i already read the incompatibility guide and various documents about VPC and VSS.
But I keep having problem with:
Connecting a Campus Distribution 6500 VSS (formaly the Core) to 2 Nexus 7000 (7702) (new core).
As the incompatibility guide says - routing between the SVI's with using VPC and MEC on VSS side is not possible.
So I want to implement L3 ports and do ECMP with EIGRP.
But how is the configuration when doing L3 portchannels in between VSS an N7K??
Is it 2 routed port/portchannel per VSS Chassis connected to both N7K's? So 4 /31 subnets??
Or is it still 1 SVI on the VSS side and 1 Portchannel to 1 big VPC on the N7K side to an HSRP VIP? Is hat supported?
Or 1 SVI on VSS and one Po to 2 VPC's(each for one N7K)?
I am quite confused what Cisco means with routing in between VSS and VPC.
BR
Alex
nazimkha
