So our monitoring software has flagged the following warning message: "chassis-2 Chassis Fan Tray 1 on 6509-quays is Critical"
Obviously this raises concerns, so I was wondering if anyone could help. I've run the environment commands and nothing seems to be flagging. The only thing I can see is the CFM values and some temperature values and was wondering if anyone could let me know if these are unhealthy or normal values to be seeing or of course there is anything else that is obvious that I am missing:
Our monitoring software has thrown up false alerts in the past, so I just wanted to find out if this was the case in this instance, or do we have a problem on our hands.
6509-quays#show env cooling
switch 1 fan-tray 1:
switch 1 fan-tray 1 type: WS-C6509-E-FAN
switch 1 fan-tray 1 mode: High-power
switch 1 fan-tray 1 fan-fail: OK
chassis per slot cooling capacity: 94 cfm
switch 1 module 1 cooling requirement: 84 cfm
switch 1 module 2 cooling requirement: 70 cfm
switch 1 module 5 cooling requirement: 84 cfm
6509-quays#show env status
switch 1 backplane:
operating clock count: 2
operating VTT count: 3
operating fan count: 1
switch 1 VTT 1:
switch 1 VTT 1 OK: OK
switch 1 VTT 1 outlet temperature: 30C
switch 1 VTT 2:
switch 1 VTT 2 OK: OK
switch 1 VTT 2 outlet temperature: 30C
switch 1 VTT 3:
switch 1 VTT 3 OK: OK
switch 1 VTT 3 outlet temperature: 29C
switch 1 clock 1:
switch 1 clock 1 OK: OK, switch 1 clock 1 clock-inuse: in-use
switch 1 clock 2:
switch 1 clock 2 OK: OK, switch 1 clock 2 clock-inuse: not-in-use
switch 1 power-supply 1:
switch 1 power-supply 1 fan-fail: OK
switch 1 power-supply 1 power-input: AC high
switch 1 power-supply 1 power-output-mode: high
switch 1 power-supply 1 incompatible with fan: OK
switch 1 power-supply 1 power-output-fail: OK
switch 1 power-supply 2:
switch 1 power-supply 2 fan-fail: OK
switch 1 power-supply 2 power-input: AC high
switch 1 power-supply 2 power-output-mode: high
switch 1 power-supply 2 incompatible with fan: OK
switch 1 power-supply 2 power-output-fail: OK
switch 1 module 1:
switch 1 module 1 power-output-fail: OK
switch 1 module 1 outlet temperature: 39C
switch 1 module 1 inlet temperature: 45C
switch 1 module 1 asic-1 temperature: 47C
switch 1 module 1 asic-2 temperature: 53C
switch 1 module 1 EARL outlet temperature: 45C
switch 1 module 1 EARL inlet temperature: 32C
The module in slot 17 does not have voice daughter
board.
switch 1 module 2:
switch 1 module 2 power-output-fail: OK
switch 1 module 2 outlet temperature: 35C
switch 1 module 2 inlet temperature: 30C
switch 1 module 2 EARL outlet temperature: 40C
switch 1 module 2 EARL inlet temperature: 30C
The module in slot 18 does not have voice daughter
board.
switch 1 module 5:
switch 1 module 5 power-output-fail: OK
switch 1 module 5 outlet temperature: 44C
switch 1 module 5 inlet temperature: 28C
switch 1 module 5 device-1 temperature: 36C
switch 1 module 5 device-2 temperature: 42C
switch 1 module 5 asic-1 temperature: 63C
switch 1 module 5 asic-2 temperature: 42C
switch 1 module 5 asic-4 temperature: 60C
switch 1 module 5 asic-5 temperature: 54C
switch 1 module 5 asic-7 temperature: 54C
switch 1 module 5 asic-8 temperature: 66C
switch 1 module 5 RP outlet temperature: 39C
switch 1 module 5 RP inlet temperature: 33C
switch 1 module 5 RP device-1 temperature: 53C
switch 1 module 5 EARL outlet temperature: 36C
switch 1 module 5 EARL inlet temperature: 29C
switch 1 module 5 EARL device-1 temperature: 62C
switch 1 module 5 EARL device-2 temperature: 63C
