02-07-2013 03:48 AM - edited 03-07-2019 11:34 AM
Hi all
On the 6509, with normal 67xx cards installed, where is all the mac table held, is it held on the card itself or on the supervisor?
and if I use dcef cards, I gather the MSFC copies the mac table to the DFC ?
Is this correct ?
02-07-2013 03:57 AM
Hi Carl,
The simple answer would be on the Sup module if the line cards doesnt have the DFC on it.
Please find the explanation below:
Catalyst switches maintain several types of tables that are tailored for Layer 2 switching or multilayer switching (MLS), and are kept in very fast memory so that many fields within a frame or packet can be compared in parallel.
In distributed switching, each Distributed Feature Card (DFC) is responsible for maintaining each own CAM table. This means that each DFC learns the MAC address and ages them, which depends on the CAM aging and traffic matching that particular entry. With distributed switching, it is normal that the supervisor engine does not see any traffic for a particular MAC address for a while, so the entry might expire. There are currently two mechanisms available to keep the CAM tables consistent between the different engines, such as DFC (present in line modules) and Policy Feature Card (PFC) (present in supervisor modules):
When a MAC address entry is aged out on the PFC, the show mac-address address
In order to prevent the age out of an entry on a DFC or PFC, even if there is not traffic for that MAC address, enable the MAC address synchronization. Issue these commands in order to enable the synchronization:
Hope this helps.
Inayath.
*Plz rate if this helps.
