6509E-VSS high CPU process due to ARP input
eek
We are experiencing with high CPU input due to ARP input between 20:30 and 22:30 every day
At this time we have a lot of backup operations. When I look the netflow report, I can't see anything anormal.
We are changing our backup server's NIC card from 1gig to 10Gig. The backup operation's traffic is high (approx 2Gbps level) but 6509 has to be handle this size of traffic.
We are using two 6509E in VSS mode
and our image version is  s72033-adventerprisek9_wan-mz.122-33.SXJ.bin
What the problem cause may be?
20:00
  show ip arp summary
  2588 IP ARP entries, with 166 of them incomplete
   show process cpu sorted
  CPU utilization for five seconds: 11%/3%; one minute: 9%; five minutes: 10%
   PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
     3         124       130        953  1.67%  0.13%  0.02%   6 SSH Process
     9     7713920    452047      17064  1.19%  0.47%  0.37%   0 Check heaps
   306    45535792 118795990        383  0.79%  0.73%  0.73%   0 Earl NDE Task
   327    18046456 124766366        144  0.71%  0.54%  0.50%   0 IP Input
   558     9185532  35575478        258  0.71%  0.36%  0.35%   0 Port manager per
    12   263195052 123093541       2138  0.47%  0.52%  0.55%   0 ARP Input
20:30
  show ip arp summary
  2587 IP ARP entries, with 165 of them incomplete
  CPU utilization for five seconds: 88%/29%; one minute: 82%; five minutes: 83%
    12   263956908 123363086       2139 42.39% 39.49% 40.28%   0 ARP Input
   397    26557084  28759093        923  4.71%  4.33%  4.32%   0 XDR mcast
     9     7721604    452477      17065  3.11%  0.52%  0.38%   0 Check heaps
   306    45582404 118903810        383  2.79%  2.38%  2.00%   0 Earl NDE Task
     3         168       130       1292  1.67%  0.13%  0.02%   6 SSH Process
21:00
show ip arp summary
  2589 IP ARP entries, with 167 of them incomplete
  CPU utilization for five seconds: 81%/27%; one minute: 83%; five minutes: 79%
    12   265046164 123738558       2141 37.91% 39.18% 37.08%   0 ARP Input
   397    26664908  28858941        923  5.43%  4.55%  4.26%   0 XDR mcast
   306    45645772 119037173        383  3.11%  2.09%  1.95%   0 Earl NDE Task
     3         176       130       1353  1.67%  0.13%  0.02%   6 SSH Process
   327    18089292 124960978        144  1.11%  0.71%  0.70%   0 IP Input
21:30
  show ip arp summary
  2589 IP ARP entries, with 168 of them incomplete
  CPU utilization for five seconds: 98%/40%; one minute: 83%; five minutes: 79%
    12   266025804 124084184       2143 41.67% 37.30% 36.26%   0 ARP Input
   397    26760700  28950445        924  4.07%  3.98%  3.92%   0 XDR mcast
    24    18692320 127459398        146  1.75%  1.07%  0.83%   0 IPC Seat Manager
     3         160       130       1230  1.67%  0.13%  0.02%   6 SSH Process
   327    18110704 125057205        144  1.27%  0.78%  0.70%   0 IP Input
22:00
  show ip arp summary
  2586 IP ARP entries, with 164 of them incomplete
  CPU utilization for five seconds: 23%/9%; one minute: 65%; five minutes: 72%
    12   266948752 124452798       2144  7.27% 28.77% 32.71%   0 ARP Input
     3         144       130       1107  1.67%  0.13%  0.02%   6 SSH Process
   306    45782092 119315110        383  1.59%  2.04%  2.08%   0 Earl NDE Task
   397    26863336  29062080        924  1.11%  3.87%  4.44%   0 XDR mcast
   327    18132460 125159162        144  0.79%  0.66%  0.69%   0 IP Input
16 Replies 16
We solved the problem.. The problem is faulty NIC card of backup server. We changed the backup server's NIC card, after then the CPU problem is gone.
Thanks for your hep Dan, it was very helpful to find problem source..
Regards..
Hi eek ,
I'm glad that your problem was solved , and also that I could help.
Also you can mark as answered your question.
Dan
