06-25-2015 10:12 AM - edited 03-08-2019 12:42 AM
Hi - I have 6513 IOS switch. I want to erase config on that and keep only 'boot system flash' command so that while reloading it don't go to rommon.
How can I do that ?
Regards, Jr.J
06-25-2015 10:17 AM
If you issue "wr erase" it will delete all the config, than save and than add the boot statement, save again, verify the boot statement exist (show boot) and also in sh run, and than reboot.
06-25-2015 05:29 PM
One more thing to add to Reza is that about the vlan.dat file in case if you dont want the vlan configured to be present you need to run this command:-
delete flash:vlan.dat
wr
reload
Inayath
