6800 ports not coming up
Hope someone can help.
I've got a pair of GLC-SX-MMD SFP's in a 6800 (also tried in a 2960).
Connecting through 5m OM3 fibers.
to an Intel E10GSFPSR dual speed 1Gb/10Gb SFP.
The server side shows the ports active in both OS and the Intel dual port NIC LED's for connection.
However Cisco side just will show nothing.  It shows the SFP in the port.  I've got light at both sides through the fibres.
Any ideas?
Thanks.
Reza Sharifi
Can you hard set the port on the switch side to Gig and try again?
Also, just for testing, you may want to swap the stands on one side of the fiber.
Hi,  Already tried that, at both ends.
It connects fine on 10G fibre, and over twinax.
Going to try different SFP's
Try to change the speed to 1000
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
I can only assume at this moment it's the GLC-SX-MMD SFP's.  The older GLX-SX-MM SFP's connect fine at 1Gbps.
