10-22-2015 02:41 AM - edited 03-08-2019 02:20 AM
i need to know when i add two supervisor engine in 6807-XL , the two supervisor engine work together i mean it will aggregate the preformance or one supervisor engine work as an active and the other one is backup (works as fail over ).
10-22-2015 03:09 AM
Active/Standby mode.
10-22-2015 03:37 AM
Can i make VSS with single chassis and 2 supervisor engine will be active ?
10-22-2015 03:46 AM
A VSS is network system virtualisation that pool multiple cisco switches into virtual switch.
Hope that clears.
-GI
Rate if it Helps
10-22-2015 03:56 AM
VSS or not, the answer is still the same: Active/Standby.
The ports on the standby supervisor card can be used but the performance ain't aggregated.
10-22-2015 03:17 AM
I am assuming you are having VSS with two chassis and two sup and what will be the role for second SUP in chassis. If yes then using VS40 technology using VSS configured with two SUP modules per chasis and second SUP play a role of SSO standby hot , which means in event of failure active SUP the standby hot SUP will immediately transition to active role within subsec.
Hope it Helps..
-GI
Rate if it Helps..
