7204 HSRP
CSCO10675262_2
I would to know if a 7204 can support hsrp within the 2 fast ethernet interfaces. E.g if fast ethernet interface 1 goes down, fast ethernet interface 2 will take over automatically.
Interface Fastethernet 0
standby 1 ip xxx.xxx.xxx.xxx
standby priority 110
standby track fastethernet 0
standby 1 preempt
Interface fastethernet 1
standby priority 100
standby track fastethernet 1
standby 1 preempt
Thanks.
Jon Marshall
Do you mean on the same router ? If so no as you cannot address the fa0 and fa1 interfaces out of the same subnet as you will get an "overlapping address" error message.
Jon
Amit Singh
Choong,
Configuration of HSRP between two interfaces on the same router is not supported and will not work. One of the restrictions in IOS is that you can not configure two active Ethernet interfaces in the same subnet. And the essence of HSRP is to have two active Ethernet interfaces in the same subnet talking to each other.
If you really want to connect two router interfaces to redundant switches and have the router interfaces back each other up, then you could try configuring bridging on both router interfaces. This would allow both interfaces to be active and Spanning Tree would provide the redundancy. To be able to route traffic from the interfaces you would need to configure IRB with a BVI interface to allow IP traffic from the router interfaces to be routed.
I would not recommend this approach, but it is the way to have both interfaces on the same router back each other up.
HTH,please rate if it does.
-amit singh
Hi, Thanks for the information.
