7206 VXR Sustained High CPU
rgoble
Level 4
Level 4
Router CPU is staying high. Any ideas. No changes to configuration in a while.
Plt-72-7206-2#show proc cpu sort | ex 0.00
CPU utilization for five seconds: 91%/87%; one minute: 88%; five minutes: 90%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  42  1116663516  34369829      32489  1.55%  1.57%  1.55%   0 Per-Second Jobs
   3       12184       479      25436  0.73%  0.18%  0.09%   2 SSH Process
   2    10062364   6316855       1592  0.24%  0.18%  0.22%   0 Load Meter
253    32905124 688870377         47  0.16%  0.10%  0.09%   0 PIM Process
254     8582756 313818474         27  0.08%  0.02%  0.02%   0 Mwheel Process
  71    18013132  31571049        570  0.08%  0.09%  0.08%   0 ct3sw_periodic 5
269    30122288 969670565         31  0.08%  0.10%  0.09%   0 PPP manager
  38    79810640  16258093       4908  0.08%  0.11%  0.10%   0 Net Background
  83   174452140 204170203        854  0.08%  0.09%  0.08%   0 IP Input
Plt-72-7206-2#sho ver
Cisco IOS Software, 7200 Software (C7200-ADVIPSERVICESK9-M), Version 12.4(15)T11, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 29-Oct-09 03:18 by prod_rel_team
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200-KBOOT-M), Version 12.4(15)T11, RELEASE SOFTWARE (fc2)
Plt-72-7206-2 uptime is 1 year, 13 hours, 48 minutes
System restarted at 22:54:51 edt Sat Jul 16 2011
System image file is "disk2:c7200-advipservicesk9-mz.124-15.T11.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G1) processor (revision B) with 983040K/65536K bytes of memory.
Processor board ID 35028224
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 180 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
3 Gigabit Ethernet interfaces
25 Serial interfaces
24 Channelized T1/PRI ports
2 Channelized T3 ports
509K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Plt-72-7206-2#show run | in cef
ip cef
Giuseppe Larosa
Hello Rgoble,
most of cpu usage is caused by interrupts with low load on processes
CPU utilization for five seconds: 91%/>>>>87%<<<<; one minute: 88%; five minutes: 90%
see the following document on how to investigate further
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml
Hope to help
Giuseppe
Will Do. Thanks!
After pursuing this with TAC it was determined that the router was getting taxed by the QOS and ACL's configured on the router. Suggestion was to upgrade to a ASR1002. The upgrade is complete and this router is running at 2% CPU as opposed to 98% CPU on the 7206. Basically the same configuration.
Hello Rgoble,
nice to see your feedback.
An ASR 1002 is a newer platform and it is not a SW only based router, it has hardware to perform QoS and ACLs filtering (ESP) so the main cpu is far less used then in C7200.
It has also much better performance on the data plane.
Hope to help
Giuseppe
