7301 hardware troubleshooting
j_poderys
Hello all,
I'm looking for anyone with an access to 7301 hardware (POST) troubleshooting docs?
I've received two decomm 7301s for the lab, and one is failing what seems to be a POST test. It fails to bring the status led to amber/green, however all fans are spinning and ethernet port leds are all green. I've tried to boot it without RAM / flash card to see if anything changes to no avail. There are 4 status leds on the motherboard that flick quickly on the working unit. On the faulty unit, 1st and 3rd leds stay on (CR4 and CR6). As the warranty period is long gone, I'm not sure if that unit can still be salvaged or if it's time to send it to recycling...
Mark Malone
If its failing POST something in hardware is usually gone and it cant start-up , could be any number of components on the board , usually with POST they got to go to TAC for an RMA or be binned , from user perspective there's not much you can do
