09-02-2013 06:17 AM - edited 03-07-2019 03:15 PM
I have a cisco 7304 thats is currently suffering from high cpu utilization due to traffic being processed switched as opposed to cef switched.
The reason for the cef drops are due to "unsupported features" however I am having trouble pin pointing why the packets being received are outside of the cef supported features. I would appriceate any insight you guys can come up with that could explain the above behaviour
I have cef enabled with valid adjacencies so as far as i can tell all packets should be cef switched. We are running a very basic config and aren’t using any of the features that are traditionally not supported by cef such as: NAT,QoS,AcL,L2VPN,PBR etc.
Hopefully the below output will provide some useful information.
High CPU
show proc cpu sort
CPU utilization for five seconds: 63%/30%; one minute: 67%; five minutes: 65%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
131 11585018281234091803 938 31.91% 33.73% 33.25% 0 IP Input
6 8305880 723241 11484 1.03% 0.24% 0.22% 0 Check heaps
59 660 303 2178 0.39% 0.64% 0.18% 2 SSH Process
CEF enabled on interface
show run | i cef
ip cef
show cef interface
GigabitEthernet0/0 is up (if_number 4)
Corresponding hwidb fast_if_number 4
Corresponding hwidb firstsw->if_number 4
Internet address is 10.200.0.13/30
ICMP redirects are never sent
IP unicast RPF check is disabled
Output features: Post-Ingress-NetFlow
IP policy routing is disabled
BGP based policy accounting on input is disabled
BGP based policy accounting on output is disabled
Hardware idb is GigabitEthernet0/0
Fast switching type 1, interface type 27
IP CEF switching enabled
IP CEF switching turbo vector
IP Null turbo vector
IP prefix lookup IPv4 mtrie generic
Input fast flags 0x0, Output fast flags 0x0
ifindex 2(2)
Slot 0 Slot unit 0 VC -1
Transmit limit accumulator 0x0 (0x0)
IP MTU 1500
slo-ce-core1a#show cef interface gi0/1
GigabitEthernet0/1 is up (if_number 5)
Corresponding hwidb fast_if_number 5
Corresponding hwidb firstsw->if_number 5
Internet address is 10.200.0.246/30
Hardware idb is GigabitEthernet0/1
ifindex 3(3)
Slot 0 Slot unit 1 VC -1
IP MTU 1500
slo-ce-core1a#show cef interface gi4/1/0
GigabitEthernet4/1/0 is up (if_number 10)
Corresponding hwidb fast_if_number 10
Corresponding hwidb firstsw->if_number 10
Internet address is 10.200.0.253/30
Input features: Ingress-NetFlow
Hardware idb is GigabitEthernet4/1/0
ifindex 8(8)
Slot 4 Slot unit 8 VC -1
IP MTU 1500
CEF unsupported drops
show ip cef switching statistics
Reason Drop Punt Punt2Host
RP LES No route 558 0 8
RP LES Packet destined for us 0 14193479 0
RP LES TTL expired 0 0 3
RP LES Bad IP packet length 8 0 0
RP LES Unclassified reason 0 12015125162 0
RP LES Total 566 12029318641 11
All Total 566 12029318641 11
IP Traffic
show ip traffic
IP statistics:
Rcvd: 3439917492 total, 14384000 local destination
3 format errors, 0 checksum errors, 0 bad hop count
0 unknown protocol, 0 not a gateway
0 security failures, 0 bad options, 0 with options
Opts: 0 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 0 alert, 0 cipso, 0 ump
0 other
Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
0 fragmented, 0 couldn't fragment
Bcast: 178931 received, 0 sent
Mcast: 0 received, 0 sent
Sent: 11638103 generated, 3411999017 forwarded
Drop: 17259721 encapsulation failed, 0 unresolved, 0 no adjacency
8 no route, 0 unicast RPF, 0 forced drop, 0 unsupported-addr
0 options denied, 0 source IP address zero
Platform info
show ver
Cisco IOS Software, 7300 Software (C7300-A3JK91S-M), Version 12.2(33)SB10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 06-Apr-11 14:36 by prod_rel_team
ROM: System Bootstrap, Version 12.1(12r)EX1, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7300 Software (C7300-BOOT-M), Version 12.2(33)SB10, RELEASE SOFTWARE (fc1)
slo-ce-core1a uptime is 5 weeks, 6 days, 13 hours, 29 minutes
Uptime for this control processor is 5 weeks, 6 days, 13 hours, 29 minutes
System returned to ROM by error - an Error Interrupt, PC 0x4098D0C0 at 00:09:46 BST Tue Jul 23 2013
System restarted at 00:44:14 BST Tue Jul 23 2013
System image file is "disk0:/c7300-a3jk91s-mz.122-33.SB10.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco 7300 (NSE100) processor (revision E) with 491520K/32768K bytes of memory.
Processor board ID SMQ1136NCK3
R7000 CPU at 350Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
4 slot midplane, Version 69.48
Last reset from software reset or reload
PXF processor tmc0 'system:pxf/ucode1' is running ( v1.0 ).
PXF processor tmc1 'system:pxf/ucode1' is running ( v1.0 ).
5 FastEthernet interfaces
4 Gigabit Ethernet interfaces
509K bytes of non-volatile configuration memory.
125440K bytes of ATA compact flash in bootdisk (Sector size 512 bytes).
250880K bytes of ATA compact flash in disk0 (Sector size 512 bytes).
slo-ce-core1a#
09-02-2013 07:39 AM
Hi ,
Curious to know whether are we using any GRE tunnel (MPLS to Ip) in this router ?
If yes please get the output of
- show pxf accounting punt (Run multipl times) - show mpls forwarding table details Regards
Partha
09-02-2013 07:57 AM
Hi Partha,
Thanks for your response.
No we are not running any GRE tunnels or MPSL on this router. its a very basic config with 2 bgp neighbours, 2 additional layer 3 interfaces and a few static routes.
Below is the output from "show pxf acc punt" I can see there is an increment on the "Null adjacency punt" however when i run the "show cef not-cef-switched" command i can see there are no "no_adj" it seems there is some contradiction between the two show commands ?
PXF punt
PXF Punt Reasons:
Non IP Punt : 727
RP IPC PAK Punt : 77212652
Broadcasts/Promiscuous Multicasts: 67912
Local Address Punt : 14214751
Null Adjacency Punt : 12044971484
Unsupported iFeature Punt: 566
PXF Punt Reasons:
Non IP Punt : 727
RP IPC PAK Punt : 77217269
Broadcasts/Promiscuous Multicasts: 67915
Local Address Punt : 14215104
Null Adjacency Punt : 12045090424
not cef switched
% Command accepted but obsolete, see 'show (ip|ipv6) cef switching statistics [feature]'
IPv4 CEF Packets passed on to next switching layer
Slot No_adj No_encap Unsupp'ted Redirect Receive Options Access Frag
RP 0 0 3455158711 0 14215321 0 0 0
09-02-2013 08:50 AM
what is the status of arp table ?
Also ,
Can you do: clear counters and capture the 'sh int stat'
30 seconds apart for 3 interations.
Just a single snapshot of 'sh int stat' isn't very helpful.
Are the counters going up continuously?
Also check: sh ip route | incl 00:00 and see if you are
seeing route churn.
Partha
09-04-2013 05:49 AM
Hi Partha,
The arp table and default route are both stable.
After clearing the counters I can still see traffic being dropped by CEF due to an unclassifyed reason.
#show ip traffic
IP statistics:
Rcvd: 17843637 total, 14911948 local destination
0 other
Bcast: 191149 received, 0 sent
Sent: 12182883 generated, 4284497968 forwarded
Drop: 17260643 encapsulation failed, 0 unresolved, 0 no adjacency
#show ip traffic
IP statistics:
Rcvd: 19058786 total, 14913038 local destination
0 other
Bcast: 191174 received, 0 sent
Sent: 12184259 generated, 4285712493 forwarded
Drop: 17260647 encapsulation failed, 0 unresolved, 0 no adjacency
09-16-2013 07:10 AM
Due to the fact that I am unable to find a reason why the traffic is not being cef switched I plan on changing the hardware. Im going to load up the same config on a new 7304 and see what the results produce.
09-16-2013 08:30 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It's been years since I worked with a 7304 with an NSE-100.
Ideally, most traffic should be forwarded by the PXF. I recall PXF was extra sensitive to the "kind" of traffic. Later IOS releases expanded the "kind" of traffic supported by the PXF. I haven't looked, but is the 12.2(33)SB10 current? If not, you might consider an IOS upgrade. Also with the PXF, often with particular IOS upgrades you were supposed to insure module firmware was current with that IOS version. Is yours?
When the PXF can't handle the traffic, then the "normal" CPU, basically a "NPE-400", forwards the traffic. Don't recall whether traffic not forwarded by the PXF shows as not CEF forwarded, or whether the non-PXF traffic is CEF forwarded or not based on its characteristics.
The reason I'm mentioning this, is because you might want to troubleshoot for PXF not forwarding, vs. CEF not forwarding first, and then perhaps non-PXF CEF vs. process switched.
09-17-2013 12:09 AM
Hi Joseph,
Many thanks for your post I appreciate your time.
Firstly we are running a basic config with only 2 bgp connections and a few static routes. I have cross checked our config with the non compatible PXF features such as NAT, QoS, VPN etc and we dont have any of those features running on this device.
Regarding the IOS upgrade, it is something I would like to do for sure however we have another 7304 running a very similar config and the same IOS, FPGA and PXF processor version and im not seeing any issues with the CEF forwarding there.
One thing I don't understand entirely is the amount of drops in "null adjacency punt" from the show PXF
accounting punt command as we have a fully populated CEF table
| Good Device | Bad Device |
| show pxf accounting punt | show pxf accounting punt |
| PXF Punt Reasons: | PXF Punt Reasons: |
| Non IP Punt : 320110 | Non IP Punt : 222 |
| IPv4 Options Punt : 118107 | RP IPC PAK Punt : 21023815 |
| RP IPC PAK Punt : 680342883 | Broadcasts/Promiscuous Multicasts: 20837 |
| Broadcasts/Promiscuous Multicasts: 42175 | Local Address Punt : 3295324 |
| Local Address Punt : 8116540 | Null Adjacency Punt : 5649246490 |
| Null Adjacency Punt : |
We already have a replacement device configured and ready to go. My concern is that I replace the device and then everything works ok. Although this would resolve the issue it wouldn't satisfy my curiosity =p
