12-07-2010 03:47 AM - edited 03-06-2019 02:23 PM
I have a customer using 7606 Router, now they are requesting for another router of same series. I can see only 7606S chasis now in the configurator.
Is 7606 and 7606S are fully compatible with modules / line cards? Can I use 7606 and 7606S together in a redundant solution?
Also the customer is asking for 4 port Gig Module, which I am not able to find from Cisco modules. is it available with Cisco?
Appreciate your quick response
Thanks and regards
Sunny
12-07-2010 06:50 AM
Thanks and regards
Sunny
Hi Sunny,
There are few difference can be listed between 7606 and 7606s which are as follows
As part of the Cisco 7600 Series, the Cisco 7606-S Router is an enhancement on the highly successful 6-slot chassis (Cisco 7606). This enhanced chassis delivers numerous design improvements, including:
1) Improved failover mechanisms in the hardware, which when paired with the proper Cisco IOS® Software image can achieve 100 ms failover.
2) High-speed fan tray module with five speeds on a side-to-side airflow design .
3) Better thermal flow measurement and management.
4) Ability to deliver higher power of up to 750W per slot.
5) The power supplies supported on the Cisco 7606-S are the 2700W AC and DC power supplies.
Check out the below link on Datasheet also for 7606s
Ganesh.H
Remember to rate the helpful post
