800 series router does not start with startup-config
gv
Could someone hel with an issue I have with a C837 ADSL router.
Whenever the router is power cycled the router goes into the intital confiration dialog.
If I show startup-config all my configuration is there. If I show the running-config it is basically like a new router.
Question is why doesn't the router use the startup-config when the appliance is powercycled.
thankyou in advance
pkhatri
Level 11
Level 11
When you issue the 'show version' command, what does it show as the configuration register value ? If it is not 0x2102, then do the following: go into configuration mode and enter in 'config-reg 0x2102' and then save the config and reboot the router.
Paresh
PS> Pls do remember to rate posts.
