802.1q trunking on ethernet
epelser_2
Can someone please confirm that it is not possible to configure 802.1q trunking on an ethernet interface. I'm busy with a lab setup and the router (a 3620) will not accept the encapsulation dot1q x (where x is the vlan number). I'm running IOS12.3 IP plus.
9 Replies 9
spremkumar
Level 9
Level 9
Can you post the output of show version here ?
regds
Thanks for the quick response. Please see the output below.
IOS (tm) 3600 Software (C3620-I-M), Version 12.2(31), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 11-Aug-05 14:30 by tinhuang
Image text-base: 0x60008930, data-base: 0x60A3E000
ROM: System Bootstrap, Version 11.1(19)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3620-I-M), Version 12.2(31), RELEASE SOFTWARE (fc2)
R6 uptime is 1 hour, 50 minutes
System image file is "flash:c3620-i-mz.122-31.bin"
cisco 3620 (R4700) processor (revision 0x81) with 28672K/4096K bytes of memory.
Processor board ID 08359841
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Configuration register is 0x2101
Regards, EP
Hi EP
The code you currently have in your box belongs to 12.2 Release and of IP Feature set.
You need to have IP PLUS feature set to have the required config in place.
you can make use of the below mentioned tool to find out the ip plus image which can fit into your current flash/dram available in place..
http://tools.cisco.com/Support/Fusion/FusionHome.do
regds
Hi Spremkumar
Could you just confirm something for me please? Do you know if this command is supported on a normal ethernet interface as apposed to a fastethernet interface. Meanwhile I'll check the memory req.
Another thing is.. I thought the MZ in the following image name indicates that this is a IP Plus image. I'm getting a bit rusty on the versions.
Thanks, EP
Hi EP
Though i haven't tried configuring IEEE 802.1q trunking on an Normal Ethernet interface i doubt on the support of the same with ethernet interfaces.
The config samples too are pointing me towards fast ethernet interfaces..
Also do refer this link..
http://www.cisco.com/univercd/cc/td/doc/product/access/mar_3200/mar_conf/m511m80.htm
regds
I've just upgraded to IP Plus version. The answer is yes, you can configure Dot1q using the encapsulation command under the subinterface using a normal ethernet interface as apposed to a fastethernet interface.
Thanks to everyone for your help.
EP
Hi EP
Good that you got your issue resolved and posted back ..
cheers..
vijayasankar
Level 4
Level 4
You should be able to do 802.1q tagging over the ethernet interface.
What is the error message that you are getting while doing so.?
Before creating the sub-interfaces, you should remove any ip address configuration done on the physical interface.
Can you post your config ?
-VJ
-VJ
vijayasankar
Level 4
Level 4
Oops. Just noticed the update from another netpro user.
Kindly ignore my previous update.
-VJ
