05-23-2019 12:13 AM
Switch 1&Switch 2
vlan 100
interface gi0/0
switch trunk encap dot
switch mode trunk
interface GigabitEthernet0/1
switchport access vlan 100
switchport mode dot1q-tunnel
media-type rj45
negotiation auto
l2protocol-tunnel cdp
l2protocol-tunnel stp
l2protocol-tunnel vtp
no cdp enable
switch 3&switch 5
vlan 14
interface GigabitEthernet0/0
switchport mode trunk
interface gi0/1
switchport access vlan 14
switchport mode access
vIOS7/vIOS9
ip address 10.0.0.1/2 255.255.255.0
duplex auto
speed auto
media-type rj45
When I did ping from 10.0.0.2 to 10.0.0.1, G0/1 in Switch 1 does not strip the outer tag 100 and when I did ping from 10.0.0.1 to 10.0.0.2, Gi0/1 in Switch 2 does not strip the outer tag 100.
here is the arp packet for ping from 10.0.0.2 to 10.0.0.1 at G0/0 Switch 3
Please help to find the reason!
05-23-2019 01:04 AM
what switch model (e.g. 3850) is this on, and what IOS version are you running ?
05-23-2019 11:13 AM
vios_l2 Software (vios_l2-ADVENTERPRISEK9-M), Version 15.2(4.0.55)E
05-28-2019 04:59 PM
it looks like QinQ works fine when adding outer vlan, but does not work when striping outer vlan.
05-29-2019 02:09 AM
your configuration looks like correct.
However, you are using some kind of virtual switch.
It can be a limitation of this platform.
On real switches your configuration will work.
Hope to help
Giuseppe
05-29-2019 12:57 PM
Hi Giuseppe, thanks so much!
