802.1X Authentication fail open
mahmoud.yasin
I have SW-2960X (OS -15.2) configured to authenticate users through RADIUS server.
I want to configure the authentication fail-open commands to grant users access to network if Radius server goes down.
But the required commands (per to Documentation) are not supported in switch!!
Switch(config)# interface fastethernet X/Y
Switch(config-if)# dot1x critical
Switch(config-if)# dot1x critical recovery action reinitialize
Switch(config-if)# dot1x critical vlan X
Any Idea?
acampbell
You need to look at the config document for the 2960-X
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_2_e/consolidated_guide/configuration_guide/b_1522e_consolidated_2960x_cg/b_consolidated_152ex_2960-X_cg_chapter_0101101.html
From IOS ver 12.2.50 onwards we now use
authentication event
under the interfaces to select what happens in server failures etc
Have a look at the doc and see what you want to happen Regards
Alex
Regards, Alex. Please rate useful posts.
