802.1x
a.hajhamad
Level 4
Level 4
I'm configuring 802.1x for secure wired access. I can't find the authentication tab for my network connection at the windows XP.
How can we enable the authentication tab? i'm using Windows XP with SP2 and Broadcom Netxtreme gigabit ethernet which i think supports 802.1x.
thanks in advance
Abd Alqader
a.hajhamad
Level 4
Level 4
solved!
it is the wireless zero configuration service was disabled.
Abd Alqader
