802.3af issues
BlakeRichardson
Meraki Community All-Star
Hi everyone
I have some MS225's that are suddenly having issues with 802.3af CCTV's cameras, the device is requesting 16w however I am aware that AF is limited to 15.4w so I suspect that the switch is not happy.
What I am seeing is the switchport has the POE icon but the background is black rather than the usual green.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
pieterh
please tell more about the question/issue?
the MS225 can supply PoE+ which means it can provide more than 15.4W, so 16W should not be a problem.
>>> suddenly having issues with 802.3af CCTV's cameras <<<
what happend before this occured? and what information can be found in the switch logs about this?
e.g. a (redundant) power supply failure ? or a firmware upgrade of either switch or CCTV camera?
