8540 CSR
mfoyster11
Can any one tell me the correct way and settings and interface to boot the 8540CSR from rommon via tftp to be able to copy an IOS image to flash card
carenas123
Level 5
Level 5
To copy the startup configuration file from the Flash memory SIMM to a Flash PC Card once the Flash PC Card is formatted and ready to use.
Copying the Startup Configuration File to the Flash PC Card.
8540CSR# copy startup-config slot0:
To create a backup copy of your system image, or to verify that the copy in Flash memory is the same as the original file on disk, you can copy system images from Flash memory to a Trivial File Transfer Protocol (TFTP) server.
