857 wireless ISR
mbluemel
I have installed several 857w ISR's and find that the wireless tends to be very flaky. I have now got one set-up in a lab environment and find that the wireless connection varies in quality even when I am right next to it. Often the link drops completely. I have tried different versions of IOS but nothing seems to solve it. Has anyone else had this problem and was there any resolution?
can you specify what problems you are running into (e.g. slow web access) ? Also, can you post the configuration of your 857 router ?
GP
The problem is that the wireless seems to fluctuate right across the board. 1mbps - 54mbps and sometimes nothing. I will post the config in the morning as I have it running in a lab at home.
in any case, check if there is some sort of electromagnetic interference, such as mobile or wireless phones. Also, do you use WEP encryption ? Possibly, if your router is not secured, somebody else might be 'stealing' your bandwidth...
GP
There is a wireless phone in the same office but I have never had a problem when using a Linksys AP. Both are using wep.
