02-14-2011 11:44 AM - edited 03-06-2019 03:32 PM
I am looking for any assistance with a new 881 W router. It has the internal AP801 (cisco AP801GN-A-K9) So far the config is very basic and I verified I have been able to connect to it. The config is below.
the issue is, the AP module continually reboots itself every 5 minutes or so. At first I thought it was the initialization of the Dot11 radio when I admin'd it up, but it keeps reloading itself.
ParknPool-FL-AP#s run
Building configuration...
Current configuration : 1423 bytes
version 12.4
no service pad
hostname ParknPool-FL-AP
enable secret 5 $1$xDgv$z7qSWYVQl9S2LNJia.jM.1
no aaa new-model
dot11 syslog
dot11 ssid ParknPool
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 0 ###############
username cisco privilege 15 secret 5 $1$/Jnc$9gCAMcPRLdmY2b9cb.uTY1
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid ParknPool
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecti
ng AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
privilege level 15
login local
no activation-character
line vty 0 4
login local
cns dhcp
end
02-14-2011 05:12 PM
Your config doesn't help. If you want to know WHY the AP constantly boots, then you need to monitor the logs of the 881 router and the logs of the 801 AP. Look into the AP's if there are any crashinfo or crash logs. Post the output for the AP:
1. dir
2. sh version
3. sh log.
Post the output of the 881 router before and after the AP boots again:
1. sh ver
2. sh log
