887VA Configuration
taycommercial
Hi...
I'm trying to configure an 887VA to work with vdsl on BT with multiple IP addresses. I have a configuration for ADSL on an 1841 so was trying to edit the config using CCP version 2.7 and download it back to the router. Every time I try I get "Changing Hostname is not suppoerted. Remove hostname to continue". If I remove the hostname I still get this message.
Has anybody got an answer to this message?
The routing will be done by a Sonicwall behind this router so any ideas on configuration would be appreciated.
Aaron Coulter
I had the same problem too. I've completely abandoned Cisco CCP. It's just too buggy. The only way to configure Cisco routers is command line as far as I'm concerned.
