887VA in bridging mode for VDSL
chriscollins
Hi all, thanks for taking the time to read my post.
I’m looking for a bit of advice on how to configure the router. I’ve found plenty of posts relating to bridging mode for ADSL but none for VDSL service.
Scenario
BT infinity service using home hub 5 (which cannot be placed in modem mode), connected to 887VA. I want to use the router in bridging so I can place a ASA5505 between the router and the LAN (ASA to have PPoE configured).
This is all sandbox at home and not a production environment. I know its overkill to use this as a bridge but I dont intend to use it forever like this and my only alternative is to purchase a vdsl modem (more expense!)
Any help to get this to work would be greatly appreciated.
Current 887VA config as below before I start mucking around.
Chris
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn xxxxxxxxxx
username admin privilege 15 secret 4
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
controller VDSL 0
interface Ethernet0
no ip address
no fair-queue
interface Ethernet0.101
encapsulation dot1Q 101
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description LAN
ip address 10.x.x.x 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Dialer1
description INFINITY
ip address negotiated
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname username@isp.com
ppp chap password 0 x
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list NAT interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended NAT
permit ip 10.x.x.0 0.0.0.255 any
remark ACCESS LIST FOR NAT
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output telnet ssh
end
Router#
HQuest
887VA(config)#controller VDSL 0
887VA(config-controller)#operating mode ?
  adsl1   ITU G.992.1
  adsl2   ITU G.992.3
  adsl2+  ITU G.992.5
  ansi    ANSI T1.413
  auto    auto detect mode
  vdsl2   ITU G.993.2
The VDSL controller on the 887VA is smart enough to detect if the line is an ADSL or VDSL. If that's an assured config for ADSL bridge, it will then work on VDSL as well. I happen to have a couple 887VA but never made them as a bridge, so I can't comment on the above config.
