9300 Cleanup Fail
harmank78
Hello, all.
On a couple of stacks, when I run "install remove inactive" I get the following message:
install_remove: START Thu Sep 12 12:02:24 EST 2024
FAILED: install_remove : The input file INVALID is not a valid file
It is version 16.5.1a.
Here is the directory:
Directory of flash:/
155674 -rwx 2097152 Sep 6 2024 14:01:49 -05:00 nvram_config
155651 -rw- 2012104 Aug 13 2017 18:43:35 -05:00 cat9k-cc_srdriver.16.05.01a.SPA.pkg
155652 -rw- 70333380 Aug 13 2017 18:43:36 -05:00 cat9k-espbase.16.05.01a.SPA.pkg
155653 -rw- 13256 Aug 13 2017 18:43:36 -05:00 cat9k-guestshell.16.05.01a.SPA.pkg
155654 -rw- 349635524 Aug 13 2017 18:43:36 -05:00 cat9k-rpbase.16.05.01a.SPA.pkg
155655 -rw- 25285572 Aug 13 2017 18:43:36 -05:00 cat9k-sipbase.16.05.01a.SPA.pkg
155656 -rw- 20947908 Aug 13 2017 18:43:36 -05:00 cat9k-sipspa.16.05.01a.SPA.pkg
155657 -rw- 2962372 Aug 13 2017 18:43:36 -05:00 cat9k-srdriver.16.05.01a.SPA.pkg
155658 -rw- 13284288 Aug 13 2017 18:43:36 -05:00 cat9k-webui.16.05.01a.SPA.pkg
155659 -rw- 13248 Aug 13 2017 18:43:36 -05:00 cat9k-wlc.16.05.01a.SPA.pkg
155660 -rw- 6681 Aug 13 2017 18:43:36 -05:00 packages.conf
155661 -rw- 24248187 Aug 13 2017 18:43:36 -05:00 cat9k-rpboot.16.05.01a.SPA.pkg
155662 -rw- 407 May 19 2019 11:45:06 -05:00 bootloader_evt_handle.log
155663 drwx 4096 Aug 13 2017 18:49:41 -05:00 core
196609 drwx 4096 Aug 13 2017 18:45:21 -05:00 .prst_sync
212993 drwx 4096 Aug 13 2017 18:45:22 -05:00 .rollback_timer
221185 drwx 4096 May 19 2019 11:45:12 -05:00 dc_profile_dir
221187 drwx 4096 Aug 13 2017 18:45:24 -05:00 gs_script
155664 -rw- 0 May 19 2019 11:45:13 -05:00 dc_stats.txt
155665 -rw- 217 May 19 2019 11:45:16 -05:00 boothelper.log
155666 -rw- 62240 May 19 2019 11:45:36 -05:00 memleak.tcl
155667 drwx 4096 Aug 13 2017 18:45:40 -05:00 .installer
155670 -rw- 35 Aug 13 2017 18:50:08 -05:00 pnp-tech-time
155671 -rw- 40728 Aug 13 2017 18:50:10 -05:00 pnp-tech-discovery-summary
155672 drwx 4096 Nov 13 2017 12:21:57 -05:00 onep
155650 -rw- 10536 Mar 4 2023 14:45:56 -05:00 vlan.dat
11353194496 bytes total (10236383232 bytes free)
My guess is that there are no inactive files to remove.  Am I right?  Or am I using the wrong command?
Thanks a bunch!
Reza Sharifi
It appears that you only have one active file here (16.05.01a). You can also use "sh inst ac" to see the active file.
Reza Sharifi
Leo Laohoo
There is nothing to clean.
