How to increase Memory or CPU usage on Catalyst 9000 Switches
esavorani
we need to carry out simulations in the laboratory and consequently allocate memory or CPU at 90% as the DNA Center has been unable on several occasions to detect this condition in the Catalyst 9200 and 9300 series switches while other SNMP monitoring tools have suffered reported the excessive use of resources.
Is there a tool or command that allocates resources on a Catalyst 9000 series switch?
Thanks for your suggestions!
Emiliano
9 Replies 9
Leo Laohoo
DNAC will not do anything even if memory utilization (data- and control plane) is >90%.
in fact this is the suspicion because for 3 times DNAC was not able to identify Core 9600 crashes and excessive memory and CPU usage showing a score of 10 and everything in green when other monitoring systems immediately noticed the problem. Now we are conducting analysis with the TAC to determine whether or not DNAC is able to identify excessive use of switch resources
one of CPU and memory issue is monitoring
try disable other monitoring and check
MHM
I guarantee DNAC does not have the function to warn if router, switch, WLC has >90% memory utilization or about to crash because of memory leak.
I know this is a true fact because we've reported this and put into "Make-A-Wish" but it was mostly ignored.
Take this for example: https://imgur.com/a/HGqH1ir
Everyone looking at this image can immediately determine it is a memory leak and it is getting worse.  DNAC does not have the "AI" to see (or "analyze") the memory.
TAC does not need to "investigate":  They already know.
If you want to generate a memory leak, it is laughably easy:
1.  Get two 9200/9300 and stack them together.
2.  Do not configure anything.
3.  Load any "gold star" IOS-XE version.
4.  Use any SNMP-based NMS and monitor the control-plane memory utilization.  In two months, the memory will slowly rise.
Joseph W. Doherty
"Is there a tool or command that allocates resources on a Catalyst 9000 series switch?"
None of which I'm aware.  I doubt Cisco would publicly document any such commands.  Such a tool could be used for DoS, so if such exists, might be found on the dark web.
Even without such commands or tools, if you have admin access to switch, I can envision some ways to hog memory and/or consume CPU, although they might not be very precise in managing degree of impact.
our case I suspect is a bug present only in 9300s that was triggered by SNMP and logging but I would like to somehow reserve memory for a process at about 90% and see if DNAC detects the condition
Funny you should mention logging as you configure a very large (up to 2 GB?) in memory system buffer.  All you then need is syslog entries to fill it.
For CPU, years ago, I found setting up a RIP neighbor, and then increasing update frequency hit a (3750's) CPU hard.
Another ways to consume memory (and CPU?) would be set up a client to pass through the switches sequential IPs to an egress interface that needs each to be ARPed.
Possibly another way to consume CPU would be a SNMP client that reads the entire MIB.
ammahend
Not aware of a command but if it’s test bed, you can try disabling spanning tree, create a loop and send a broadcast, might help.
-hope this helps-
