9300 DHCP static binding not working
Hello
I am trying to get a DHCP static binding with a binding file to work. I already managed to connect multiple clients with the switch and they recieve the correct IP Address assigned in the DHCP static binding file. There is one client, where it does not seem to work. I already tried it with 01 prefix and without. The bindings look like this:
IP address Client-ID/ Lease expiration Type State Interface
192.168.2.6 0030.5336.a7fe Sep 30 2022 11:52 AM Automatic Active Vlan1
192.168.2.35/24 0100.3053.36a7.fe Infinite Static Active Unknown
192.168.2.36/24 0030.5336.a7fe Infinite Static Active Unknown
My dhcp pools look like this:
ip dhcp pool static-bus
origin file flash:/static-binding.txt
default-router 192.168.2.5
dns-server 192.168.2.5
ip dhcp pool dynamic-bus
network 192.168.2.0 255.255.255.0
So the client recieves an IP from the dynamic address pool, but it should recieve one from the static binding.
The difference between this client and all my other clients is, that this client uses PoE. Does this affect the hardware type in the static binding file?
Are there any suggestions why the binding is not working?
15 Replies 15
Hello
Can you reset the camera and also clear any dhcp bindings referencing its mac- address and test again?
Kind Regards
Paul
I have reset everything and I'm using just the one static binding now that i want to apply, it still doesnt work.
!IP address Type Hardware address Lease expiration
192.168.2.36 01 0030.5336.a7fe Infinit
*end*
Without the dynamic DHCP active, the camera recieves 169.254.75.51 now as an IP.
This is the Output of the Syslog if it helps to resolve the issue:
*Sep 30 10:04:30.526: DHCPD: DHCPDISCOVER received from client 0030.5336.a7fe on interface Vlan1.
let first refresh the DHCP static by
no service dhcp
then
service dhcp
I always do that when applying a new configuration.
can I see the config file ?
I attached the startup conf and the static-binding file. I also attach a screenshot of the dhcp bindings:
As already mentioned, the .35 is the one not working.
last thing share the below
debug ip dhcp server events
NOTE:- disable debug after finish
I check and check,
first think
the debug not see SW read infinite word, I return to your text
you typo write infinit not infinite
can you please edit this word and check again.
I corrected the typo, the problem still persists.
no service dhcp
then
service dhcp
then check debug see if the SW read the text file, your previous (last) debug dont show that SW read text file
Yes, it does still read the text file:
Hello
You have L2 security on the switch( dhcp snooping/IPSG ) but also DHCP service active which seems counter-intuitive!
Is vlan 1 the only vlan being serviced with dhcp ?
Can you try enabling ip routing on the switch then fresh the dhcp service and test again.
Kind Regards
Paul
im new to the networking world, so i dont really know what dhcp snooping/L2 Security  is about.
Yes, Vlan1 is the only existing Vlan and therefore the only Vlan being serviced with DHCP.
I did enable IP routing, but still get the same results. Logs and current config are attached.
