Making a C9300 switch a gateway
Gator
Greetings:
I have a C9300 switch and a Sophos firewall in a medium sized network. Currently the gateway of the network is the firewall. I have heard its better practice to make the C9300 the gateway. What would i need to do on the switch to make that happen ? please and thanks.
balaji.bandi
If you looking to control the traffic between any VLAN, i prefer to have FW as Gateway, so you can deny example :
VLAN 10 and VLAN 20 do not like to talk each otehr FW you can block.
If you looking to Move the gateway on switch you need to create VLAN SVI as Layer 3 interface and assign a IP address, so user can point that as gateway, again you need to make some static routing here between FW and Switch.
if this is simple network i do not see any advantage moving gateway back to Switch (until you see reason and greedy to move the Gateway to switch).
BB
Joseph W. Doherty
"I have heard its better practice to make the C9300 the gateway."
That depends on your traffic flows, local vs. non-local.
The C9300 likely has much more routing capacity than your FW.  If you have lots of traffic that transits your C9300, which needs to hop between your local networks, then yes, C9300 probably a better choice for such routing.  However, if most of your traffic is not hopping between networks, locally, but passing through your FW, FW is fine for your L3 "routing".
One quick test, if you only have one gateway, locally, you likely wouldn't benefit from C9300 being the gateway.  Even if you had lots of local gateways, unless traffic is between your local networks, again, C9300 likely wouldn't benefit you being the gateway.
If you do believe you have much local traffic between your local networks, let us know, and we can discuss what you may need to do.
FW as GW meaning all traffic is inspect in FW, making the SW as GW meaning the traffic not hit the FW and hence the FW will not inspect the traffic.
"FW as GW meaning all traffic is inspect in FW, making the SW as GW meaning the traffic not hit the FW and hence the FW will not inspect the traffic."
Very true.
However, often, but not always, we use FWs, and their deep inspection capabilities for traffic flowing in/out of our network, i.e. not for traffic totally flowing just within our network.
Also, basic between networks security can be implemented on a C9300.
Again, there are times when the capabilities of a FW are wanted for internal traffic too, so that's something to not forget.
