9300 switch hardware compatibility with 3850/3750
uppermost
Level 2
Level 2
Does anyone know if below modules are compatible with 9300-48UN and whether they support 10MB?
3850-NM-2-10G
C3KX-NM-10G
Yes @uppermost
Best regards
6 Replies 6
M02@rt37
Hello @uppermost,
As concerned C3KX-NM-10G module, it fits Cisco Catalyst 3650-X and 3750-X switches.
Best regards
uppermost
Level 2
Level 2
Are u 100% sure ? because I know that C3850-NM-4-1G works on 9300-48UN
So that means that 3850-NM-2-10G is in fact compatible?
Yes @uppermost
Best regards
Leo Laohoo
3850-NM-2-10G can be used on the 9300.
The power supplies for the 3750X and the 3850 are the same as the ones used in 9300.  They have different SKU to "encourage" people to buy the 9300 power supplies.
