9300 upgrade not applying
Rick001
I have a 3 switch stacked 9300 that I am trying to upgrade from 17.09.01 to 17.09.04.
I have copied the bin file through a USB Flash Drive using the following commands:
copy "usbflash0:cat9k_iosxe.17.09.04.SPA.bin" flash:
config t
boot system cat9k_iosxe.17.09.04.SPA.bin
exit
reload
#show boot system
Switch 1
Current Boot Variables:
BOOT variable = flash:cat9k_iosxe.17.09.04.SPA.bin;
Boot Variables on next reload:
BOOT variable does not exist
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
Switch 2
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
Switch 3
Manual Boot = no
Enable Break = no
Boot Mode = DEVICE
iPXE Timeout = 0
#show issu state detail
Current ISSU Status: Disabled
Previous ISSU Operation: N/A
System Check Status
Platform ISSU Support Yes
Standby Online No
Autoboot Enabled Yes
SSO Mode Yes
Install Boot Yes
Valid Boot Media Yes
Operational Mode NONE
No ISSU operation is in progress
When it starts up it is still on 17.09.01.
#show install summary
[ Switch 1 2 3 ] Installed Package(s) Information:
State (St): I - Inactive, U - Activated & Uncommitted,
C - Activated & Committed, D - Deactivated & Uncommitted
Type St Filename/Version
IMG C 17.09.01.0.178
Auto abort timer: inactive
#sh log
Log Buffer (8112 bytes):
RVED_INSTALLED: Specific License Reservation Authorization code installed for udi PID:C9300-48T,SN:
*Oct 24 11:22:13.057 GMT: %SMART_LIC-6-RESERVED_INSTALLED: Specific License Reservation Authorization code installed for udi PID:C9300-48T,SN:
*Oct 24 11:22:13.190 GMT: %SMART_LIC-6-RESERVED_INSTALLED: Specific License Reservation Authorization code installed for udi PID:C9300-24T,SN:
*Oct 24 11:22:13.191 GMT: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowed
*Oct 24 11:22:13.200 GMT: %SMART_LIC-6-RESERVED_INSTALLED: Specific License Reservation Authorization code installed for udi PID:C9300-48T,SN:
*Oct 24 11:22:13.209 GMT: %SMART_LIC-6-RESERVED_INSTALLED: Specific License Reservation Authorization code installed for udi PID:C9300-48T,SN:
*Oct 24 11:22:13.881 GMT: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TEST_CISCO_IDEVID_SUDI has been generated or imported by pki-sudi
*Oct 24 11:22:13.916 GMT: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: TEST_CISCO_IDEVID_SUDI0 created succesfully
*Oct 24 11:22:13.917 GMT: %CRYPTO_ENGINE-5-KEY_DELETED: A key named TEST_CISCO_IDEVID_SUDI has been removed from key storage
*Oct 24 11:22:13.932 GMT: %PKI-6-TRUSTPOINT_DELETE: Trustpoint: TEST_CISCO_IDEVID_SUDI deleted succesfully
*Oct 24 11:22:13.934 GMT: %PKI-6-TRUSTPOINT_DELETE: Trustpoint: TEST_CISCO_IDEVID_SUDI0 deleted succesfully
*Oct 24 11:22:13.934 GMT: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: TEST_CISCO_IDEVID_SUDI created succesfully
*Oct 24 11:22:13.941 GMT: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TEST_CISCO_IDEVID_SUDI has been generated or imported by pki-sudi
*Oct 24 11:22:13.959 GMT: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: TEST_CISCO_IDEVID_SUDI0 created succesfully
*Oct 24 11:22:13.961 GMT: %CRYPTO_ENGINE-5-KEY_DELETED: A key named TEST_CISCO_IDEVID_SUDI has been removed from key storage
*Oct 24 11:22:13.962 GMT: %PKI-6-TRUSTPOINT_DELETE: Trustpoint: TEST_CISCO_IDEVID_SUDI deleted succesfully
*Oct 24 11:22:13.963 GMT: %PKI-6-TRUSTPOINT_DELETE: Trustpoint: TEST_CISCO_IDEVID_SUDI0 deleted succesfully
*Oct 24 11:22:13.964 GMT: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI created succesfully
*Oct 24 11:22:13.971 GMT: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported by pki-sudi
*Oct 24 11:22:14.009 GMT: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI0 created succesfully
*Oct 24 11:22:14.010 GMT: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI_LEGACY created succesfully
*Oct 24 11:22:14.017 GMT: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI_LEGACY has been generated or imported by pki-sudi
*Oct 24 11:22:14.035 GMT: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI_LEGACY0 created succesfully
*Oct 24 11:22:29.001 GMT: %PLATFORM_PM-6-FRULINK_INSERTED: 8x10G uplink module inserted in the switch 2 slot 1
*Oct 24 11:22:29.537 GMT: %PLATFORM_PM-6-FRULINK_INSERTED: 8x10G uplink module inserted in the switch 3 slot 1
*Oct 24 11:22:31.268 GMT: %PLATFORM_PM-6-MODULE_INSERTED: SFP module inserted with interface name Te2/1/3
*Oct 24 11:22:31.771 GMT: %PLATFORM_PM-6-MODULE_INSERTED: SFP module inserted with interface name Te3/1/3
*Oct 24 11:22:33.537 GMT: %SMART_LIC-6-RESERVED_INSTALLED: Specific License Reservation Authorization code installed for udi PID:C9300-24T,SN:
*Oct 24 11:22:33.537 GMT: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowed
*Oct 24 11:22:33.546 GMT: %SMART_LIC-6-RESERVED_INSTALLED: Specific License Reservation Authorization code installed for udi PID:C9300-48T,SN:
*Oct 24 11:22:33.558 GMT: %SMART_LIC-6-RESERVED_INSTALLED: Specific License Reservation Authorization code installed for udi PID:C9300-48T,SN:
*Oct 24 11:22:33.605 GMT: %CALL_HOME-6-CALL_HOME_ENABLED: Call-home is enabled by Smart Agent for Licensing.
*Oct 24 11:22:33.729 GMT: %SMART_LIC-6-REPORTING_REQUIRED: A Usage report acknowledgement will be required in 0 days.
*Oct 24 11:22:35.800 GMT: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/1/3, changed state to up
*Oct 24 11:22:36.154 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/11, changed state to up
*Oct 24 11:22:36.800 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1/3, changed state to up
*Oct 24 11:22:36.835 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan3804, changed state to up
*Oct 24 11:22:37.089 GMT: %LINK-3-UPDOWN: Interface TenGigabitEthernet3/1/3, changed state to up
*Oct 24 11:22:37.154 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/11, changed state to up
*Oct 24 11:22:37.284 GMT: %LINK-3-UPDOWN: Interface GigabitEthernet3/0/11, changed state to up
*Oct 24 11:22:38.023 GMT: %OSPF-5-ADJCHG: Process 1, Nbr on Vlan38 from LOADING to FULL, Loading Done
*Oct 24 11:22:38.089 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet3/1/3, changed state to up
*Oct 24 11:22:38.093 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan38, changed state to up
*Oct 24 11:22:38.289 GMT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3/0/11, changed state to up
*Oct 24 11:22:40.573 GMT: %OSPF-5-ADJCHG: Process 1, Nbr on Vlan38 from LOADING to FULL, Loading Done
Oct 24 11:23:09.193 GMT: %PKI-6-AUTHORITATIVE_CLOCK: The system clock has been set.
Oct 24 11:24:01.787 GMT: %IOSXE_REDUNDANCY-6-PEER: Active detected switch 2 as standby.
Oct 24 11:24:01.786 GMT: %STACKMGR-6-STANDBY_ELECTED: Switch 1 R0/0: stack_mgr: Switch 2 has been elected STANDBY.
Oct 24 11:24:11.872 GMT: %REDUNDANCY-5-PEER_MONITOR_EVENT: Active detected a standby insertion (raw-event=PEER_FOUND(4))
Oct 24 11:24:11.872 GMT: %REDUNDANCY-5-PEER_MONITOR_EVENT: Active detected a standby insertion (raw-event=PEER_REDUNDANCY_STATE_CHANGE(5))
Oct 24 11:24:29.622 GMT: %SSH-5-SSH2_SESSION: SSH2 Session request from (tty = 0) using crypto cipher 'aes128-ctr', hmac 'hmac-sha2-256' Succeeded
Oct 24 11:25:03.700 GMT: %SMART_LIC-6-RESERVED_INSTALLED: Specific License Reservation Authorization code installed for udi PID:C9300-24T,SN:
Oct 24 11:25:03.700 GMT: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowed
Oct 24 11:25:03.711 GMT: %SMART_LIC-6-RESERVED_INSTALLED: Specific License Reservation Authorization code installed for udi PID:C9300-48T,SN:
Oct 24 11:25:03.720 GMT: %SMART_LIC-6-RESERVED_INSTALLED: Specific License Reservation Authorization code installed for udi PID:C9300-48T,SN:
Oct 24 11:25:08.034 GMT: %HA_CONFIG_SYNC-6-BULK_CFGSYNC_SUCCEED: Bulk Sync succeeded
Oct 24 11:25:09.047 GMT: %RF-5-RF_TERMINAL_STATE: Terminal state reached for (SSO)
Oct 24 11:25:09.308 GMT: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: anguser] [Source: ] [localport: 22] at 11:25:09 GMT Tue Oct 24 2023
Oct 24 11:25:09.308 GMT: %SSH-5-SSH2_USERAUTH: User '' authentication for SSH2 Session from (tty = 0) using crypto cipher 'aes128-ctr', hmac 'hmac-sha2-256' Succeeded
Oct 24 11:27:58.306 GMT: %PLATFORM-4-ELEMENT_WARNING: Switch 1 R0/0: smand: 2/RP/0: limited space - copy files out of flash: directory. flash: value 77% (8573 MB) exceeds warning level 70% (7760 MB).
Oct 24 11:27:58.304 GMT: %PLATFORM-4-ELEMENT_WARNING: Switch 2 R0/0: smand: 2/RP/0: limited space - copy files out of flash: directory. flash: value 77% (8573 MB) exceeds warning level 70% (7760 MB).
Oct 24 11:28:04.539 GMT: %PLATFORM-4-ELEMENT_WARNING: Switch 1 R0/0: smand: 3/RP/0: limited space - copy files out of flash: directory. flash: value 77% (8573 MB) exceeds warning level 70% (7760 MB).
Oct 24 11:28:04.537 GMT: %PLATFORM-4-ELEMENT_WARNING: Switch 2 R0/0: smand: 3/RP/0: limited space - copy files out of flash: directory. flash: value 77% (8573 MB) exceeds warning level 70% (7760 MB).
Oct 24 11:33:31.758 GMT: %SYS-5-CONFIG_I: Configured from console by anguser on vty0 ()
Oct 24 11:35:07.253 GMT: %SYS-5-CONFIG_I: Configured from console by anguser on vty0 ()
Once the switch is completely booted, try to negate the old ios and add the new one:
no boot system bootflash:<old ios>
boot system bootflash:<new ios>
verify with "sh boot" that the correct IOS is there.
save and reload
7 Replies 7
Rick001
I tried a couple times and noticed that when the switches came back up they went into diagnostic mode (switch#) and had to apply the firmware from the USB one by one in the stack with the following command:
boot usbflash0:cat9k_iosxe.17.09.04.SPA.bin
After the switch restarted, it applied the updated firmware and was seen as part of the stack.
save and reload
Rick001
I had tried the no boot system on a 4 switch stack and when I reloaded it only applied on switch 1. The rest only showed switch: on the console and had to run the command boot usbflash0:cat9k_iosxe.17.09.04.SPA.bin on each switch with the USB Flash drive connected to each one.
So, all 4 switches now have the new IOS installed and booted correctly?
Yes, after I ran the command boot usbflash0:cat9k_iosxe.17.09.04.SPA.bin it rebooted and applied the update. I just had to do it for each switch in the stack and can't do it remotely.
Leo Laohoo
Cisco 3850: IOS-XE/Firmware Upgrade
NOTE
The above process is compatible with the 9300/9300X, however, in Step 6 (to check if the packages.conf file is pointing to the correct target version), use the command "more flash-X:packages.conf | begin rp_boot" (where "X" is the switch member number).
