9500 StackWise Virtual Configuration Question
dorchard83
Frequent Visitor
Frequent Visitor
Hi everyone,
About to implement StackWise Virtual and just had a question about the configuration.
We currently have one C9500-16X in production, we’ve just purchased another and getting ready to implement.
Plan is to configure the existing switch as the master by defining a higher priority.
Once StackWise is formed will all the previous configuration still exist?
I assume it does but just wanting to double check as I haven’t been able to test this prior to implementation.
Giuseppe Larosa
Hello @dorchard83 ,
the configuration should be kept as the already powered on device should be the master.
However, making a backup of the configuration is recommended.
see the following thread
https://community.cisco.com/t5/switching/cisco-9600-stackwise-virtual-file-configuration/m-p/4019046
Hope to help
Giuseppe
Thanks for the reply @Giuseppe Larosa,
One other question, I'll be upgrading the current 9500 from 16.8.1a to 16.12.3a, which will mean there's a requirement to configure the smart licencing call home.
Does is matter if this is configured before or after the StackWise virtual is configured?
