A CoPP and Class Map Question - HURRY! :-)
lamav
Level 8
Level 8
Here is my CoPP policy in its entirety. Focus on the ACLs and class map, not the policing at the bottom.
ip access-list extended ROUTING_TRAFFIC
remark CoPP OSPF Traffic Class
permit ospf any any
ip access-list extended MANAGEMENT_TRAFFIC
remark CoPP for Network Management Traffic
permit udp host 10.41.248.129 host 64.13.44.104 eq snmp
permit udp host 10.41.168.24 host 64.13.44.104 eq ntp
permit tcp any gt 1024 any eq SSH
permit tcp any eq SSH any gt 1024 established
permit tcp any any eq ftp
permit tcp any any eq ftp-data
permit tcp any any eq 1812
permit tcp any any eq 1813
ip access-list extended ICMP_TRAFFIC
remark CoPP for ICMP Traffic
permit icmp any any echo
permit icmp any any echo-reply
permit icmp any any ttl-exceeded
permit icmp any any packet-too-big
permit icmp any any port-unreachable
permit icmp any any unreachable
ip access-list extended UNDESIRABLE_TRAFFIC
remark CoPP for All Potentially Malicious Traffic
permit icmp any any fragments
permit udp any any fragments
permit tcp any any fragments
permit ip any any fragments
permit udp any any eq 1434
permit tcp any any eq bgp rst
ip access-list extended GENERAL_TRAFFIC
remark CoPP for General Traffic
permit ip any any
class-map CRITICAL_TRAFFIC
description ROUTING UPDATES
match access-group ROUTING_TRAFFIC
class-map IMPORTANT_TRAFFIC
description MANAGEMENT TRAFFIC
match access-group MANAGEMENT_TRAFFIC
class-map NORMAL_TRAFFIC
description ICMP TRAFFIC
match access-group ICMP_TRAFFIC
class-map UNDESIRABLE_TRAFFIC
description MALICIOUS TRAFFIC
match access-group UNDESIRABLE_TRAFFIC
class-map GENERAL_TRAFFIC
description ALL OTHER TRAFFIC
match access-group GENERAL_TRAFFIC
policy-map ROUTER_COPP
class CRITICAL_TRAFFIC
police 1000000 50000 50000 conform-action transmit exceed-action transmit
class IMPORTANT_TRAFFIC
police 100000 20000 20000 conform-action transmit exceed-action drop
class NORMAL_TRAFFIC
police 50000 5000 5000 conform-action transmit exceed-action drop
class GENERAL_TRAFFIC
class Undesirable
police 8000 1500 1500 conform-action drop exceed-action drop
Question:
In the class map, should I use math-all or match-any?
I think match-any, right? I say this because each class map matches an ACL with several statements/flows in it. The active flow I want to police should only need to match itself in the ACL to have the CoPP policy applied. If I do match-all, the data flow must match ALL the criteria in the ACL before the CoPP is applied, and, of course, I dont want that, right?
Am I reading this wrong? Also, I forgot what the default is if you dont specify match-all or match-any....
need answers in a hurry! :-)
Yup, you got it. Let us know if you have any other questions!
HTH,
Craig
5 Replies 5
xcz504d1114
Level 4
Level 4
You must use match-any or match-all if more than one match criteria exist. So using just "match" wouldn't work if you are matching multiple criteria. But I don't see any of your class-maps that have multiple match criteria in them. It looks like you could combine "NORMAL_TRAFFIC" and "GENERAL_TRAFFIC" in a match-any class-map though
You are correct, if you use match-any, if any one of the conditions are met, it performs the action, if you use match-all, all criteria must be met before the action is performed.
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfmdcli.html
HTH,
Craig
xcz504d1114
Level 4
Level 4
Just for clarification, even though you have multiple lines on your ACL, that does not constitute as multiple criteria, that will act as a match any, so if any traffic matches any of your permit lines, it will apply the policy to that traffic.
HTH,
Craig
OK, I think I get it.
In the class map, the "match any" or 'match all" is referring to the match criteria within the class map itself, NOT the ACL statements...right?
So, in my case, I am only using ONE match command in the class map - matching to an ACL for that type of traffic, so I could use mtch all OR match any...wouldnt make a difference, right??
HTH,
Craig
Victor,
How have you been? (grin)
Toshi
