A noob issue about recursively routed
wandering_997
Hi all,
Here's my configuration.
r2#show ip route
Gateway of last resort is not set
12.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 12.1.1.0/24 is directly connected, Serial1/0
S 12.1.1.1/32 [1/0] via 12.1.1.1
r2#
r2#show run int s1/0
interface Serial1/0
ip address 12.1.1.2 255.255.255.0
encapsulation frame-relay
end
r2#
r2#
r2#show run | include ip route
ip route 12.1.1.1 255.255.255.255 12.1.1.1
r2#
r2#
Let's ping 12.1.1.1 at r2, can r2 get the icmp reply from 12.1.1.1 ?
Why?
Wandering
dario.didio
Level 4
Level 4
no, your ping will not work.
If you remove the static route, it will work.
reason is that if you ping 12.1.1.1, the static route will be used because it is more specific than the connected route. (sh ip route 12.1.1.1).
The destination for the static route is again 12.1.1.1, and the story goes on...
Why do you want to configure it like this?
HTH,
Dario
Hi Dario,
Thank you for your reply.
Yes, you're right, it does't work.
This is not a requirement, but a accident of my colleague.
I didn't believe that untill I made a lab.
I'm wondering why it exists? It looks like a serious bug of routing mechanism.
And I made a /32 route to a host in the same segment on my laptop system, the host can be pinged successfully.
wandering@d630:~> route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
10.217.15.11 10.217.15.11 255.255.255.255 UGH 0 0 0 eth0
10.217.15.0 0.0.0.0 255.255.255.0 U 1 0 0 eth0
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
0.0.0.0 10.217.15.1 0.0.0.0 UG 0 0 0 eth0
wandering@d630:~>
wandering@d630:~> ping -c 1 10.217.15.11
PING 10.217.15.11 (10.217.15.11) 56(84) bytes of data.
64 bytes from 10.217.15.11: icmp_seq=1 ttl=64 time=0.735 ms
--- 10.217.15.11 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.735/0.735/0.735/0.000 ms
wandering@d630:~>
Why? Is IOS different from Unix like system?
Wandering
