AAA not working for telnet or SSH, works for HTTP - Cat 3750G
OldGreyBeast
I know it's old, but I've got 2 48p Catalyst 3750Gs running IOS 15.  I've setup SSH on cat switches before without issue but for some reason this one is just being super resistant.  I can log in with my user account to the HTTP interface without any issues, but it says login failed for both SSH and telnet.  I've generated the rsa keys and whatnot, putty connects just fine, it just always says that authentication failed.  It does this with both accounts i've added.  Both accounts work fine on HTTP.
version 15.0
no service pad
service password-encryption
hostname house-cat3750G
boot-start-marker
boot-end-marker
no logging console
enable secret 5 [redacted]
username [redacted] secret 5 [redacted]
aaa new-model
aaa authorization exec default local
aaa session-id common
clock timezone UTC -6 0
clock summer-time UTC recurring
switch 1 provision ws-c3750g-48ps
system mtu routing 1500
ip domain-name DOMAIN.com
[interface/crypto key configs removed to save space]
interface Vlan99
ip address 10.10.10.1 255.255.255.0
no ip route-cache
ip default-gateway 10.10.10.254
ip http server
ip http secure-server
vstack
line con 0
line vty 0 4
session-timeout 28800
password 7 [redacted]
transport input telnet ssh
transport output telnet ssh
line vty 5 15
end
28 Replies 28
Ok, I followed the steps above (including creating the mhm account).  I'm unable to login via SSH or telnet.  I'm also now unable to access the console again.  All 3 of these accounts are very simple (jason/jason, admin/admin, mhm/mhm) so I know I'm not mis-keying the passwords.
Do you think I should drop this switch back to 12.2?
Give me half hour I will try config in my lab.
MHM
username [redacted] secret 5 [redacted] <<- these not work
OldGreyBeast
Correct, neither account works.
enable password mhm
aaa new-model
aaa authentication login default local
username mhm password 0 mhm
username mhm2 privilege 15 password 0 mhm2
interface Ethernet0/0
ip address 100.0.0.1 255.255.255.0
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
Hmm, what version of IOS is your lab running?  My GNS3 instance has 12.2.  Curious if it's something weird with 15.0.
I Dont think so'
Only add username password with privilege and remove password from line.
I fiddled with it for a while and couldn't get it to work.  Cleared the entire config, built it back exactly like yours, and it still doesn't work.  Any time I turn on aaa, it locks me out of console, telnet, and SSH.
I'm going to try reverting it to 12.2 tomorrow and see if that makes a difference.
Downgraded from 15.0(2) to the latest 12.2 and the issue is resolved.
Very odd, but at least I know I wasn't being stupid.
Oh happy ending
with your original config or with my config, which is work ?
I loaded my original config back into it before doing the downgrade
Thank you for all your help!
You are so so welcome
have a nice day friend
MHM
