AAA not working for telnet or SSH, works for HTTP - Cat 3750G
OldGreyBeast
I know it's old, but I've got 2 48p Catalyst 3750Gs running IOS 15.  I've setup SSH on cat switches before without issue but for some reason this one is just being super resistant.  I can log in with my user account to the HTTP interface without any issues, but it says login failed for both SSH and telnet.  I've generated the rsa keys and whatnot, putty connects just fine, it just always says that authentication failed.  It does this with both accounts i've added.  Both accounts work fine on HTTP.
version 15.0
no service pad
service password-encryption
hostname house-cat3750G
boot-start-marker
boot-end-marker
no logging console
enable secret 5 [redacted]
username [redacted] secret 5 [redacted]
aaa new-model
aaa authorization exec default local
aaa session-id common
clock timezone UTC -6 0
clock summer-time UTC recurring
switch 1 provision ws-c3750g-48ps
system mtu routing 1500
ip domain-name DOMAIN.com
[interface/crypto key configs removed to save space]
interface Vlan99
ip address 10.10.10.1 255.255.255.0
no ip route-cache
ip default-gateway 10.10.10.254
ip http server
ip http secure-server
vstack
line con 0
line vty 0 4
session-timeout 28800
password 7 [redacted]
transport input telnet ssh
transport output telnet ssh
line vty 5 15
end
28 Replies 28
aaa authentication login default local <<- this for telnet
for SSH
you need ip domain-name and RSA before you can access via SSH
https://www.cisco.com/c/en/us/support/docs/security-vpn/secure-shell-ssh/4145-ssh.html
NOTE:- you need username xxx password xxx and enable password xxx before enable auth via aaa
OldGreyBeast
Hi, yes I've already done the ip domain-name and RSA.
Aaa auth login is missing
OldGreyBeast
Ok, I added:
No change in behavior though.
Same then try
Add under line vty
Login auth defualt
OldGreyBeast
Ok, added that.  Still no change in behavior
Username xxx previllige 15 password xxx << - add this
OldGreyBeast
so after adding the aaa authentication login default local I lost the ability to login via the serial cable (which is why I didn't have that line in the config initially).  Switch is rebooting to undo the aaa auth at the moment.
Sorry can you elaborate more' how aaa auth effect access via console ?
It will prompt for a username and password at the serial connection.
Neither of the usernames/passwords specified will work.  I'm not able to leave the username blank and use the enable password.
Ok, switch rebooted.  I added the aaa authentication line /only/ under vty 0 15.  This still doesn't allow login.
I deleted the second user and added a new user:
username admin password 0 admin priv 15
Still unable to login.
Just one second'
You can access via console and do config ?
But still can not access via telnet and ssh ?
Sorry I missed this reply.  Yes, after rebooting the switch (which reverted the aaa auth) I am able to access the console port without credentials and make config changes.
If I add the aaa authentication line back, username/password is required via the serial console and I'm unable to log in due to it not accepting the credentials.
aaa need
NO aaa authorization exec default local
username mhm privilege 15 password mhm
enable password mhm
under the line of vty
login authenation default
NOTE:- please dont copy run to start, in case this config not work you can access via console
