AAA Web Authentication on Cisco 3850 switch fails
Abdullah Shabir
Hi all,
I have an issue in which the radius-based authentication works fine for SSH but it doesn't work for web login. When I change it to local-based authentication then I am able to log in. I have tested the following:
Disabled and enabled the http and https server but it didn't fix the problem.
Added the command ip http client source-interface vlan 7 (this is the management VLAN and default-gateway is set to VLAN 7's SVI/gateway)
The error I get is as below:
%WEBSERVER-5-LOGIN_FAILED:Switch 1 R0/0: : Login Un-Successful from host XX.XX.XX.XX  by user 'XXXXX'
the firmware version for the switch is  16.3.6.
DanielP211
Hello Abdullah,
Which commands are you using? If you want to use the radius/tacacs, thy using the following commands:
ip http authentication aaa login-authentication default
ip http authentication aaa exec-authorization default
BR,
Daniel
****Kindly rate all useful posts*****
Hi Daniel,
I have tried these commands and it is still not working.
I send you private message
