about bittorrent.pdlm,please help me
xfei_sars
hi,everyone
i have a 3640 router with c3640-i-mz.12.2-12c.bin IOS and i donwloaded the new bittorent PDLM to block the bitcomet application . i loading the pdlm by examples and make a test on the Bitcomet application,but do not limiting the Bitcomet application.
please help me.ASAP...
show run:
ip subnet-zero
ip cef
ip nbar pdlm flash:bittorrent.pdlm
class-map match-all bittorrent
match protocol bittorrent
policy-map bittorrent-policy
class bittorrent
police 8000 1500 1500 conform-action transmit exceed-action drop violate-ac
tion drop
controller E1 0/0
controller E1 0/1
interface FastEthernet0/0
ip address 192.168.30.200 255.255.255.0
ip nat outside
ip nbar protocol-discovery
duplex auto
speed auto
service-policy input bittorrent-policy
service-policy output bittorrent-policy
interface FastEthernet2/0
ip address 10.0.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
Router#sh flash
System flash directory:
File Length Name/status
1 6166828 c3640-i-mz.122-12c.bin
2 3100 bittorrent.pdlm
[6170056 bytes used, 10607160 available, 16777216 total]
16384K bytes of processor board System flash (Read/Write)
8 Replies 8
xfei_sars
regards
xfei
hai there :)
just googling,
try this link
http://cetamac.blogspot.com/2006/01/alternative-managing-bittorrent.html
rgds,
hw
network.king
Level 4
Level 4
Hi ,
Can u pls check wheter you are getting traffic in the class you have defined.
sh policy-map interface fa2/0 bittorrent-policy input
regards
vanesh k
this
Router#sh policy-map interface fa 2/0
FastEthernet2/0
Service-policy input: bittorrent-policy
Class-map: bittorrent (match-all)
1386 packets, 695870 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: protocol bittorrent
police:
8000 bps, 1500 limit, 1500 extended limit
conformed 1206 packets, 454815 bytes; action: transmit
exceeded 111 packets, 149892 bytes; action: drop
violated 69 packets, 91163 bytes; action: drop
conformed 0 bps, exceed 0 bps, violate 0 bps
Class-map: class-default (match-any)
1002783 packets, 807842225 bytes
5 minute offered rate 1057000 bps, drop rate 0 bps
Match: any
Service-policy output: bittorrent-policy
235 packets, 108644 bytes
police:
conformed 218 packets, 83572 bytes; action: transmit
exceeded 11 packets, 16108 bytes; action: drop
violated 6 packets, 8964 bytes; action: drop
765505 packets, 441246343 bytes
5 minute offered rate 670000 bps, drop rate 0 bps
Match: any
Hi ,
As per your output , policing is working fine for bittorent .
pls let me know what is the problem you are facing now.
regard
vanesh k
thx for your reply
that is a test on my backup router.if the test succeeded,i will do it on my router.But do not limiting the Bitcomet application now,i still have a upload(200k+) and download(200k+)on my test pc(only one). so i need your help,pls help me,thank u
regard
xfei
Hi Saif,
Pls do one thing to see wheter bitcomet is using some other protocols also , under the police command , give a drop for the confirmed packets too .
pls check and let us know.
regards
vanesh k
xfei_sars
regards
xfei
