about show tech command
dotansplus
Hi everyone, I'm doing a performance report, I have the output of show tech command, I'm considering the cpu and memory information for my performance report, but Im not sure about the normal operation, there is some parameter for a normal operation?, for example a router 2900, and whitch commands also I have to considering fomr my performance report?, I want a good inform for my lab, any help is welcome.
Thanks in advance.
InayathUlla Sharieff
You can use outlook interpreter you would get some idea
I think that you're talking about the output interpreter
https://www.cisco.com/pcgi-bin/Support/OutputInterpreter/home.pl
cheers.
Yes Dotansplus.
