About syslog severity and how to setup
Arijit007
I am new to networking. I have questions on syslog severity. Now below is the chart that i got from cisco website.
Q1> If I chose to send severity 6 logs then will it send informational logs along with it's 0-5 severity logs to syslog server?? Or only information logs will be sent?
Q2> What kind of logs are sent in informational logs? What is the recommended one to choose?
Q3> Can we choose to send all type logs to syslog server? is it recommended? Will it affect any system performance?
Q4>Also what is the log type for below and will it be sent to syslog server if severity chosen 6?
%IOSXE_INFRA-6-PROCPATH_CLIENT_HOG: IOS shim client 'chasfs' has taken 252 msec (runtime: 252 msec) to process a 'stack chasfs fd' message
Log severity table-
Level KeywordLevelDescriptionSyslog Definition
emergencies
System unstable
LOG_EMERG
alerts
Immediate action needed
LOG_ALERT
critical
Critical conditions
LOG_CRIT
errors
Error conditions
LOG_ERR
warnings
Warning conditions
LOG_WARNING
notifications
Normal but significant condition
LOG_NOTICE
informational
6
Informational messages only
LOG_INFO
debugging
7
Debugging messages
LOG_DEBUG
Richard Burts
Q1- if you specify severity level 6 for sending logs to the server then Informational and all other more severe levels (0 5) will be sent.
Q2- it is difficult to say what is included and much easier to say what is not included in level 6, which is debug output. This is a common choice in specifying what logs should be sent to the syslog server. Some people want to reduce the load on the syslog server and specify severity levels below 6. We do not know anything about your environment and what severity level is appropriate for you.
Q3- For most environment sending syslog messages to a server does not take much processing power and does not consume much bandwidth. There are certainly some situations where this is not the case (especially if severity level 7 was chosen). We do not have enough information to know how it would impact your situation.
Q4- if you specify severity 6 that log message would be sent to the server.
Rick
