accesing a 2960 switch with no configured password
vic.mejia
hello:
I configure a stack of 2960 xr switches with a username and password (using the secret password)
Username XXXXX privilege 15 secret
but forgot to enter the : enable secret  xxxxx     as part of the configuration
the problem is that I have console port enable to use the secret password for authentication. and so I cannot access the switch
how can I get access to the stack , if it asking for a password , yet I forgot to put in the enable secret password
how do I set the switch to factory default
thanks,
7 Replies 7
Reza Sharifi
You don't need to erase the config.  Just use the link to do a password recovery:
http://www.rogerperkin.co.uk/cisco/switching/password-recovery-cisco-2960x/
Hello, Reza:
I try that option.. the problem is that there is no password configured
the above local username is using the enable secret to be able to log in :
the line consol is using login local
so when I connect via console its going to ask for the username / enable secret password in order to put me straight into priv mode.. but the problem is that I didn't configured the enable secret
so there is no password to authenticate against
if your doing a password recovery it should bypass all passwords secret and aaa , and then you reset the passwords when it breaks you back into running-config.
It doesn't take me into a running-config
when I do the flash_init
then the next option is to boot:
after the boot , it just reboots normaly and comes up asking for username/ password  prompts
it doesn't ask me if i want to config the switch.
I followed the same procedure in the password recovery mechanism. and rename the config file.
thanks..
the problem that I was having was that when I did step 5 below, as indicated in the document it didn't work, but when I rename the file to config.old.text  the procedure worked..instead of config.text.old
thanks,
Step 5 Rename the configuration file to config.text.old This file contains the password definition. Switch: rename flash: config.text flash: config.text.old
The password recovery procedure should make you bypass all passwords.  It should look as the device has no password/username, etc.. anymore.
Have a look at this doc for 2960 xr series:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960xr/software/15-0_2_EX1/system_manage/configuration_guide/b_sm_152ex1_2960-xr_cg/b_sm_152ex1_2960-xr_cg_chapter_0111.html#task_544E27675C2748079213063119729B7A
