Access List help
Anand Narayana
Level 6
Level 6
i hav the network like this........
Internet Router----->ASA------>3750
now on 3750 i hav created 5 vlans, ASA will be a part of 1 vlan in 3750, rest 4 vlans will be on LAN.
my requirement is......
all the 4 vlans users in LAN should be accessed based on the rules applied in ASA & not in 3750.
which means all the routing should happen via ASA & not 3750, but VLAN should be created only in 3750..
5 Replies 5
cpembleton
Level 4
Level 4
In order for your ASA to do the routing you'll need to create a sub-interfaces off the inside interface. One for each vlan on the switch.
Example:
interface gigabitEthernet0/0
no shut
interface GigabitEthernet0/0.10
description VLan 10
vlan 10
nameif inside10
security-level 100
ip address 192.168.1.10 255.255.255.0
interface GigabitEthernet0/0.20
description Vlan 20
vlan 20
nameif inside20
security-level 100
ip address 192.168.1.20 255.255.255.0
interface GigabitEthernet0/0.30
vlan 30
nameif inside30
security-level 100
ip address 192.168.1.30 255.255.255.0
Chad
Please rate if helpful.
Hi Anand,
Agree with Chad on this. You have to configure a dot1q trunk between 3750 and ASA. Donot create the SVI's on 3750 and set the gateway for the hosts as the sub-interface IP of the ASA for respective vlans.
Please see the document below for more help.
http://www.cisco.com/en/US/partner/products/ps6120/products_configuration_guide_chapter09186a0080636f42.html#wp1044006
HTH,please rate if it does.
-amit singh
Hi Cblem & Amith,
Thanks for ur reply, but i hav PIX Version 6.3(3) running on my Firewall on other side office, so how do i create sub-interface. the interface in pix is like this........ "ip address inside 192.168.1.1 255.255.255.0"
can i have something like this for having multiple logical interfaces.
nameif vlan2 inside security50
nameif vlan3 inside security50
nameif vlan4 inside security50
ipaddress inside 192.168.1.1 255.255.255.0
ipaddress inside 192.168.2.1 255.255.255.0
ipaddress inside 192.168.3.1 255.255.255.0
if not, how do i assign a single with multiple ip address for each & every vlan?
how to i connect to the switch, i mean if i put "switch port mode trunk" on the switch side, what command should i need on the PIX "inside" interface? in router the command is "encapsulation dot1Q 1"
