AccessList
Navaz Wattoo
Level 4
Level 4
I configured the below acl and only permit 192.168.0.0 and 172.168.20.42 and 172.16.20.97.
access-list 100 permit icmp 192.168.10.0 0.0.0.255 any
access-list 100 permit tcp 192.168.10.0 0.0.0.255 any
access-list 100 permit udp 192.168.10.0 0.0.0.255 any
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
access-list 100 permit icmp host 172.16.20.42 any
access-list 100 permit tcp host 172.16.20.42 any
access-list 100 permit udp host 172.16.20.42 any
access-list 100 permit ip host 172.16.20.42 any
access-list 100 permit icmp host 172.16.20.97 any time-range Test
access-list 100 permit tcp host 172.16.20.97 any time-range Test
access-list 100 permit udp host 172.16.20.97 any time-range Test
access-list 100 permit ip host 172.16.20.97 any time-range Test
time-range Test
 periodic weekdays 8:30 to 18:00
 periodic Saturday 8:30 to 15:00
interface Vlan11
 description DB SERVERS
 ip address 192.168.11.254 255.255.255.0
 ip access-group 100 out
Requirement:-
Now i want to permit all host for a specific machine like 192.168.11.18 that are exist in vlan11.
Navaz
8 Replies 8
Eugene Khabarov
Level 11
Level 11
It's simple:
access-list 100 permit ip any host 192.168.11.18
I configured but its not working. please check this.
access-list 100 permit icmp host 172.16.10.166 any
access-list 100 permit tcp host 172.16.10.166 any
access-list 100 permit udp host 172.16.10.166 any
access-list 100 permit ip host 172.16.10.166 any
access-list 100 permit icmp host 172.16.31.24 any
access-list 100 permit tcp host 172.16.31.24 any
access-list 100 permit udp host 172.16.31.24 any
access-list 100 permit ip host 172.16.31.24 any
access-list 100 permit icmp host 172.16.31.26 any
access-list 100 permit tcp host 172.16.31.26 any
access-list 100 permit udp host 172.16.31.26 any
access-list 100 permit ip host 172.16.31.26 any
access-list 100 permit icmp host 172.16.31.31 any
access-list 100 permit tcp host 172.16.31.31 any
access-list 100 permit udp host 172.16.31.31 any
access-list 100 permit ip host 172.16.31.31 any
access-list 100 permit icmp host 172.16.71.37 any
access-list 100 permit tcp host 172.16.71.37 any
access-list 100 permit udp host 172.16.71.37 any
access-list 100 permit ip host 172.16.71.37 any
access-list 100 permit icmp host 172.16.31.25 any
access-list 100 permit tcp host 172.16.31.25 any
access-list 100 permit udp host 172.16.31.25 any
access-list 100 permit ip host 172.16.31.25 any
access-list 100 permit icmp host 172.16.31.45 any
access-list 100 permit tcp host 172.16.31.45 any
access-list 100 permit udp host 172.16.31.45 any
access-list 100 permit ip host 172.16.31.45 any
access-list 100 permit icmp host 172.16.71.32 any
access-list 100 permit tcp host 172.16.71.32 any
access-list 100 permit udp host 172.16.71.32 any
access-list 100 permit ip host 172.16.71.32 any
access-list 100 permit icmp host 172.16.71.33 any
access-list 100 permit tcp host 172.16.71.33 any
access-list 100 permit udp host 172.16.71.33 any
access-list 100 permit ip host 172.16.71.33 any
access-list 100 permit icmp host 172.16.83.5 any
access-list 100 permit tcp host 172.16.83.5 any
access-list 100 permit udp host 172.16.83.5 any
access-list 100 permit ip host 172.16.83.5 any
access-list 100 permit icmp host 172.16.83.1 any
access-list 100 permit tcp host 172.16.83.1 any
access-list 100 permit udp host 172.16.83.1 any
access-list 100 permit ip host 172.16.83.1 any
Navaz
#show ip access-lists 100
You should see matches in specific ACEs.
These are the output
DHA-Core-SW#sh ip access-lists 100
Extended IP access list 100
    10 permit icmp host 172.16.10.166 any
    20 permit tcp host 172.16.10.166 any
    30 permit udp host 172.16.10.166 any
    40 permit ip host 172.16.10.166 any
    50 permit icmp 192.168.10.0 0.0.0.255 any (2380 matches)
    60 permit tcp 192.168.10.0 0.0.0.255 any (83159 matches)
    70 permit udp 192.168.10.0 0.0.0.255 any (4424 matches)
    80 permit ip 192.168.10.0 0.0.0.255 any
    90 permit icmp host 172.16.31.24 any
    100 permit tcp host 172.16.31.24 any (36 matches)
    110 permit udp host 172.16.31.24 any
    120 permit ip host 172.16.31.24 any
    130 permit icmp host 172.16.31.26 any
    140 permit tcp host 172.16.31.26 any
    150 permit udp host 172.16.31.26 any
    160 permit ip host 172.16.31.26 any
    170 permit icmp host 172.16.31.31 any
    180 permit tcp host 172.16.31.31 any (321 matches)
    190 permit udp host 172.16.31.31 any
    200 permit ip host 172.16.31.31 any
    210 permit icmp host 172.16.71.37 any
    220 permit tcp host 172.16.71.37 any
    230 permit udp host 172.16.71.37 any
    240 permit ip host 172.16.71.37 any
    250 permit icmp host 172.16.31.25 any
    260 permit tcp host 172.16.31.25 any (229 matches)
    270 permit udp host 172.16.31.25 any
    280 permit ip host 172.16.31.25 any
    290 permit icmp host 172.16.31.45 any
    300 permit tcp host 172.16.31.45 any (34 matches)
    310 permit udp host 172.16.31.45 any
    320 permit ip host 172.16.31.45 any
    330 permit icmp host 172.16.71.32 any
    340 permit tcp host 172.16.71.32 any (50 matches)
    350 permit udp host 172.16.71.32 any
    360 permit ip host 172.16.71.32 any
    370 permit icmp host 172.16.71.33 any
    380 permit tcp host 172.16.71.33 any
    390 permit udp host 172.16.71.33 any
    400 permit ip host 172.16.71.33 any
    410 permit icmp host 172.16.83.5 any
    420 permit tcp host 172.16.83.5 any (295 matches)
    430 permit udp host 172.16.83.5 any
    440 permit ip host 172.16.83.5 any
    450 permit icmp host 172.16.83.1 any (27 matches)
    460 permit tcp host 172.16.83.1 any (216 matches)
    470 permit udp host 172.16.83.1 any (2 matches)
    480 permit ip host 172.16.83.1 any
    490 permit ip any host 192.168.11.18 (31 matches)
Navaz
So as you can see rule 490 - there is match and it works fine.
Post your full config and scheme if you have any more issues
interface Vlan39
 description DB-SERVERS
interface Vlan40
 ip address 172.16.10.254 255.255.255.0 secondary
 ip address 192.168.10.254 255.255.255.0
 no ip redirects
 ip policy route-map bypassproxy
ip route 10.1.1.0 255.255.255.0 192.168.13.249
access-list 1 permit 172.16.31.18
access-list 1 permit 172.16.130.0 0.0.0.255
access-list 1 permit 172.16.131.0 0.0.0.255
access-list 1 permit 172.16.132.0 0.0.0.255
access-list 1 permit 172.16.71.0 0.0.0.255
access-list 1 permit 172.16.100.0 0.0.0.255
access-list 1 permit 172.16.133.0 0.0.0.255
access-list 2 permit 172.16.131.0 0.0.0.255
access-list 2 permit 172.16.140.0 0.0.0.255
access-list 2 permit 172.16.150.0 0.0.0.255
access-list 2 permit 172.16.120.0 0.0.0.255
access-list 2 permit 172.16.100.0 0.0.0.255
access-list 180 permit tcp host 172.16.199.11 any eq www
access-list 180 permit tcp host 172.16.199.10 any eq www
access-list 180 permit tcp host 172.16.71.10 any eq www
access-list 180 permit tcp host 172.16.71.0 any eq www
access-list 180 permit tcp host 172.16.72.0 any eq www
access-list 180 permit tcp host 172.16.73.0 any eq www
access-list 180 permit tcp host 172.16.81.0 any eq www
access-list 180 permit tcp host 172.16.82.0 any eq www
access-list 180 permit tcp host 172.16.83.0 any eq www
access-list 180 permit tcp host 172.16.84.0 any eq www
access-list 180 permit tcp host 172.16.11.0 any eq www
access-list 180 permit tcp host 172.16.12.0 any eq www
access-list 180 permit tcp host 172.16.13.0 any eq www
access-list 180 permit tcp host 172.16.14.0 any eq www
access-list 180 permit tcp host 172.16.21.0 any eq www
access-list 180 permit tcp host 172.16.22.0 any eq www
access-list 180 permit tcp host 172.16.23.0 any eq www
access-list 180 permit tcp host 172.16.24.0 any eq www
access-list 180 permit tcp host 172.16.31.0 any eq www
access-list 180 permit tcp host 172.16.32.0 any eq www
access-list 180 permit tcp host 172.16.33.0 any eq www
access-list 180 permit tcp host 172.16.34.0 any eq www
access-list 180 permit tcp host 172.16.100.0 any eq www
access-list 180 permit tcp host 172.16.130.0 any eq www
access-list 180 permit tcp host 172.16.131.0 any eq www
access-list 180 permit tcp host 172.16.132.0 any eq www
access-list 180 permit tcp host 172.16.31.59 any eq ftp
access-list 180 permit tcp host 172.16.41.0 any eq www
access-list 181 permit ip any host 174.142.165.146
access-list 181 permit ip any host 202.142.160.2
access-list 181 permit ip any host 202.141.224.34
access-list 181 permit ip any host 8.8.8.8
access-list 181 permit tcp host 172.16.31.59 any eq ftp
access-list 181 permit tcp host 172.16.71.40 any eq ftp
access-list 199 permit ip host 172.16.199.80 any
access-list 199 permit ip host 172.16.199.40 any
access-list 199 permit ip host 172.16.199.39 any
access-list 199 permit tcp host 172.16.199.10 any eq www
route-map ptcl permit 10
 match ip address 2 22 1
 set ip default next-hop 172.16.120.241
route-map bypassproxy permit 180
 match ip address 180
 set ip next-hop 10.1.1.103
route-map bypassproxy permit 181
 match ip address 181
 set ip next-hop 192.168.13.249
route-map bypassproxy permit 199
 match ip address 199
Navaz
please remove your confidential information from config here (community, passwords etc.)
Please do theneedful solution. its not working
Navaz
