ACE Load Balancer
shyamatopsource
I am a newbie in this forum.. Can you please tell me whether I can specify a range of ports from the Public IP to the Internal servers. Normally the F5 does not allow you to add range of ports for a mapping..
Shyam
spremkumar
Level 9
Level 9
Hi Shyam
If you are asking about doing the static port translation in your Cisco box ofcourse its possible to do the same.
you can refer the below link to get started..
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_white_paper09186a0080091cb9.shtml
regds
