ACL-Cisco
1381-alizare
Community Member
Hello, I have a network like this. And I want to establish the access of some users to certain IPs in the network by defining the access list. And I also want to connect people who are in a series of VLAN to the Internet. I use a MikroTik1100 router for the organization's internet and I used a core 3750 switch in layer 2 of my network. I don't want to close layer 3 access in the local network from the router. I want to do layer 3 network with access list in core switch. But even though I wrote ACL, the connection is still not established correctly.
10 Replies 10
@1381-alizare
Share the show running config from switches. And the information from where to where you want to block the traffic
Current configuration : 4412 bytes
! Last configuration change at 08:54:10 UTC Sun Nov 10 2024
version 15.2
service compress-config
hostname Switch
boot-start-marker
boot-end-marker
enable password 1234
username ali privilege 15 password 0 1234
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/0
switchport mode trunk
ip access-group VLAN_ACCESS in
media-type rj45
negotiation auto
interface GigabitEthernet0/1
media-type rj45
negotiation auto
interface GigabitEthernet0/2
media-type rj45
negotiation auto
interface GigabitEthernet0/3
media-type rj45
negotiation auto
interface GigabitEthernet1/0
media-type rj45
negotiation auto
interface GigabitEthernet1/1
media-type rj45
negotiation auto
interface GigabitEthernet1/2
media-type rj45
negotiation auto
interface GigabitEthernet1/3
media-type rj45
negotiation auto
interface GigabitEthernet2/0
media-type rj45
negotiation auto
interface GigabitEthernet2/1
media-type rj45
negotiation auto
interface GigabitEthernet2/2
media-type rj45
negotiation auto
interface GigabitEthernet2/3
media-type rj45
negotiation auto
interface GigabitEthernet3/0
media-type rj45
negotiation auto
interface GigabitEthernet3/1
media-type rj45
negotiation auto
interface GigabitEthernet3/2
media-type rj45
negotiation auto
interface GigabitEthernet3/3
no switchport
ip address dhcp
negotiation auto
interface Vlan1
ip address 192.168.1.2 255.255.255.0
interface Vlan10
ip address 192.168.10.2 255.255.255.0
ip helper-address 192.168.1.1
interface Vlan20
ip address 192.168.20.2 255.255.255.0
interface Vlan30
ip address 192.168.30.2 255.255.255.0
ip forward-protocol nd
ip http server
no ip http secure-server
ip access-list extended ALLOW_SPECIFIC
permit ip host 192.168.20.253 host 192.168.10.254
permit ip host 192.168.10.254 host 192.168.20.253
deny ip any any
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS *
* education. IOSv is provided as-is and is not supported by Cisco's *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any *
* purposes is expressly prohibited except as otherwise authorized by *
* Cisco in writing. *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
end
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#
Extended IP access list VLAN_ACCESS
10 permit ip host 192.168.20.253 host 192.168.10.254
20 deny ip any any (25 matches)
Switch(config)#
I did not see the command "ip routing" on the switch. Whithout It, there Will be no communication between VLANs. Meaning, you dont need ACL because host on vlan 10 Will not reach host in vlan 20. Unless you are using another device as layer3
You applied the ACL VLAN_ACCESS
But I dont see this ACL created anywhere
I see the one below
ALLOW_SPECIFIC
Yes, I fixed it now, but it still does not connect
____
Building configuration...
Current configuration : 4524 bytes
! Last configuration change at 10:27:07 UTC Sun Nov 10 2024
version 15.2
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
no switchport
ip address dhcp
negotiation auto
interface Vlan1
interface Vlan10
interface Vlan20
ip access-group ALLOW_SPECIFIC in
interface Vlan30
ip http server
deny ip any any
ip access-list extended VLAN_ACCESS
deny ip any any
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
end
that is true:
Current configuration : 4533 bytes
! Last configuration change at 10:39:35 UTC Sun Nov 10 2024
version 15.2
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
no switchport
ip address dhcp
negotiation auto
interface Vlan1
interface Vlan10
interface Vlan20
interface Vlan30
ip http server
deny ip any any
deny ip any any
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
1381-alizare
Community Member
this is true:
version 15.2
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
no switchport
ip address dhcp
negotiation auto
interface Vlan1
interface Vlan10
interface Vlan20
interface Vlan30
ip http server
deny ip any any
deny ip any any
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
The ACL config looks ok.
You need "ip routing" command. Otherwise, they will be no routing between vlan.
 Can I see the output of
Show version and show license?
you need to check
show access-list <<- check hit in ACL I see ACL INbound under VLAN SVI
this I think prevent PC from ping it GW
MHM
