ACL magic
csco11579831
please do you know the one config ACL that allows only allow the exchange of files between two hosts, (ptotocole TCP / UDP Port eq?)
Best regards,
8 Replies 8
James Neilson
permit tcp host x.x.x.x host x.x.x.x eq PORT
permit udp host x.x.x.x host x.x.x.x eq PORT
deny ip any any
Hi James,
I'm looking for ports that allow file sharing
the server ports should be TCP 139 and TCP 445 for file sharing.
Alain
does not working
i think that, but also does not working
access-list 110 deny tcp host x.x.x.x host y.y.y.y range 137 139
access-list 110 deny udp host x.x.x.x host y.y.y.y range netbios-ns netbios-ss
it should be a permit not a deny otherwise you'll be filtering file sharing.
alain
Surely!!! but I use it for a road map,
deny or permit isn't necessary for me :), the most important thing is the port(udp,tcp and
range netbios-ns netbios-ss....)
James
How can you know if it is working then ?
Alain
no access-list 110
access-list 110 deny tcp 172.16.5.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 110 deny tcp 172.16.5.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 110 deny tcp 172.16.5.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 110 permit tcp 172.16.5.0 0.0.0.255 any
here is my access-list,
I observation of huge slow (1.5 Mb / s) on a conversation file sharing between host and 172.16.5.X 172.16.0.X, well if I target the port file sharing on first access-list I have an easy conversation between the two hosts,
